Old 07-27-2003, 08:05 PM
EvenAce EvenAce is offline
Default Ableton live as a ReWire slave in PT6.1?
I'n my quest to get VSTi's to work in Pro Tools 6.1 I noticed on the Ableton Live website that the new version of Live will work as a ReWire slave in ProTools, similar to how Reason works.
The point I noted was that Live supports VST instruments. Does this mean that you would be able to use VSTi's inside Live then inside Pro Tools??!??
I'd be very keen on such a setup, although I'm probably only dreaming, I bet when you use it as a ReWire slave, the VST's dont work or something... VST's and Pro Tools just dont seem to wanna mix! [img]images/icons/wink.gif[/img]
Anyways, if anyone knows anything more about this, please post!!
EvenAce
Old 07-27-2003, 08:32 PM
Shan's Avatar
Shan Shan is offline
Default Re: Ableton live as a ReWire slave in PT6.1?
I'm not sure about Ableton but there are a few guys here using Project 5 for the very application that you are describing.
Shan
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 07-28-2003, 01:18 AM
jim jedlicka jim jedlicka is offline
no, vst's do not work in ableton live in rewire mode.But as said above ,cakewalk's project 5 can be used in rewire mode to play vst's.
Jim Jedlicka
Old 07-28-2003, 07:06 AM
Thanks for your responses guys. I got an e-mail back from Ableton tech support and that told me the 'bad' news! [img]images/icons/tongue.gif[/img]
I used to use Cakewalk back in the day, so I'll check out that Project 5!
Cheers,
EvenAce
Ableton Live rewire slave into PT workflow vudoo Pro Tools TDM Systems (Mac) 5 10-18-2015 05:33 PM
Live won't run as ReWire Slave. Tim R. Pro Tools TDM Systems (Mac) 2 06-05-2005 08:05 PM
...need some help with ableton live as PT LE slave dlae Tips & Tricks 3 11-08-2004 04:03 AM
Using Live 1.5.2 as a Rewire slave in PTLE 6.1.1.. soundboy69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-01-2003 11:52 AM
Ableton Live 2.1 as Rewire Slave in Pro Tools 6.1??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-29-2003 03:36 PM
