Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 06-06-2021, 05:01 PM
cunninghamaudio cunninghamaudio is online now
Default S1 / Eucon Customization
Does anyone know if there is a way to set the colors on the SI User Keys to display the colors you set in Eucontrol rather than the tracks?
Also, does anyone know if there is a way to use one of those buttons to cycle the open plug in windows through Inserts A-J? I'm using one of those keys through Eucontrol to open plugin window (Eucon-Navigation-Windows-Plugin Window) and it only opens insert A. Is there way to then toggle through the rest of the inserts on that channel or select which one? I tried the DYN / EQ cycle and it doesn't seem to do anything.
I'm hoping there is an option like the D Command had to open the plugin window and then cycle through.
Old 06-07-2021, 10:03 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: S1 / Eucon Customization
The colors currently follow the track colors. We do have a task in the backlog to add this and multi S1 Softkeys.
I don't know of a way to cycle the Inserts, but it has been requested before so we can look at how to do it.
Dock Touch Strips Customization Lynn Gräber Avid S1, S3, Dock and Control 2 02-26-2020 11:05 PM
iMac Pro Customization Options - Thoughts? DAWgEAR macOS 88 04-06-2018 02:57 PM
Pt9 gui customization Chavdadd macOS 4 07-25-2011 08:29 AM
Venue Profile Boot Screen Customization? voidmix VENUE Live Sound Systems 2 03-03-2011 12:35 PM
Plug-in Menu Customization... danander11 General Discussion 5 08-17-2009 05:04 PM
