Old 06-13-2010, 11:06 AM
vudoo vudoo is offline
Default Ableton Live rewire slave into PT workflow
I'm curious how people use Live in this particular situation : as slave rewire into PT ( or any other DAW ) or Live MTC along with another DAW.
show me you workflow !
Old 06-13-2010, 01:12 PM
tlennon tlennon is offline
Default Re: Ableton Live rewire slave into PT workflow
Slave rewire.
Terrence Lennon
Ivory Key Productions
Old 06-13-2010, 10:40 PM
muhis1 muhis1 is offline
I've "rewired" Live a couple of times to PT...but the sad thing about Live is that
it doesn't allow you to use 3rd part plugins when in rewire mode.
Otherwise it works great!
Mac Pro Nehalem 2,66 with 12 GB ram, Pro Tools 8.1, HD2 Accel, 192 I/O with 2 882s, UAD 2 QUAD OMNI. OSX 10.6.4
Old 11-07-2011, 06:12 AM
baka baka is offline
I use Live as rewire slave to PT all the time. Never used to have any problems, but since PT9 (&10) if tempo is variable when you press "stop" all kinds of weird loops from rewire play simultaneously until the curser is placed at the end of the song (this doesn't happen if section played has no tempo changes).
Also I am now unable to use the time selector within Live as I was before. If a time selction needs to be made it has to be done within Protools - bit of a pain but work-roundable.
Old 10-18-2015, 04:53 PM
tudznsudz tudznsudz is offline
Have you found a solution to this weird loop problem? Currently having a huge issue using PT11 and Live 9...every time I stop playback after a tempo change the audio coming from Live goes crazy...
Old 10-18-2015, 05:33 PM
soul's Avatar
soul soul is offline
Rewire slave has limited features in Live such as no Max4Live plugs and you cant record anything. Also frequent loop issues and crashes abound. Its really not a friendly combo.
When I know am going to do a lot of work in live, I make PT stems and import them while I use Live as standalone. Then I go back to slave rewire once all the Live parts are done and record them into PT.
my 2 cents
PT HD4 v.10.3.8 / Mac OS 10.8.2 / Intel Core i7 3.4Ghz / McDSP CompressorBank & FilterBank / Eventide Anthology / Ableton Live 9 Suite
Live rewire or MTC into PT...show me your workflow vudoo Virtual Instruments 2 06-13-2010 01:06 PM
Live won't run as ReWire Slave. Tim R. Pro Tools TDM Systems (Mac) 2 06-05-2005 08:05 PM
...need some help with ableton live as PT LE slave dlae Tips & Tricks 3 11-08-2004 04:03 AM
Ableton Live 2.1 as Rewire Slave in Pro Tools 6.1??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-29-2003 03:36 PM
Ableton live as a ReWire slave in PT6.1? EvenAce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-28-2003 07:06 AM
