Old 06-07-2010, 08:33 PM
chirnover chirnover is offline
Default Need conversion from 6-circuit firewire to 4-circuit socket in laptop
Hi i've got a rack 003 which has a 6-circuit firewire 400 plug and I'm looking to get that plugged into my computer which only has usb 2.0 & a 4-circuit firewire socket. What would be the best way to convert this without losing speed on data transfer. Thanks
Old 06-07-2010, 08:44 PM
Default Re: Need conversion from 6-circuit firewire to 4-circuit socket in laptop
the extra pins on the 6 pin fw is for power. you are not losing any data speed. you can go pickup a 6 to 4 pin fw cable at about any electronics or computer supply or online.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 9900k
Win 10
Old 06-07-2010, 08:47 PM
rqstudio rqstudio is offline
My guess is just to use a 4-circuit firewire cable which would (I believe) not carry power which again I believe you would not need going from an 003 to a loptop or powered ext drive. But that may be the least of your problems, not many laptops are qualified to run PT efficiently.
www.rickqueststudio.com
Old 06-09-2010, 03:23 AM
Thanks a lot for that, I'll get the cable
Does Digi sell the Fader circuit board for the 002 Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2010 07:36 AM
Eq or other plug in 'in circuit'? RaySoul General Discussion 8 01-23-2010 11:51 PM
Issue? Laptop, Firewire 410, SIIG Firewire Express Card batchmister1 Pro Tools M-Powered (Win) 2 08-07-2009 10:37 AM
Firewire Cards for 002 - With AMD 64 x2 - AM2 Socket - ERROR *DELETED* Table Syrup Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-18-2007 09:52 AM
P-4 systems, Socket 423 or Socket 478?? Rudger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-25-2002 10:25 PM
