Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-02-2008, 12:38 PM
dkaudio dkaudio is offline
Question recorded audio will not playback
Well I have a recorded audio that seems to be getting into the program ( I can see the waveform while it's recording) but once the recording stops the waveform disapears and the track is pink with no waveform and no audio..please help!!!!
Old 11-03-2008, 01:58 PM
DigiTechSupt's Avatar
Default Re: recorded audio will not playback
We're going to need more info to help you.
See the Help Us Help You thread for details.
As a start, make sure you've installed the latest CS update for the version of Pro Tools you're running.
Avid Audio Tech Support
Support FAQ
Old 11-06-2008, 05:46 AM
clausiii's Avatar
clausiii clausiii is offline
Do you hear your recorded files?
If yes try the following:
If your track view is set to "blocks" try "waveform" instead...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 11-07-2008, 04:09 PM
O.k. I'm not seeing a waveform now..when I first started to see if I could get some input I did see a waveform but no audio on playback....now I just see a pink block with not wave for and not audio...I think I might now what the problem is...my drive is formatted for HFS...I think I need to get a new drive and re-format it in OSX...The drives that I have were formatted in OS9 for digital performer...
My mac is older as well..1 ghz processor, 2mb L3 Cache, 1.5 gb ram, bus speed is 133mhz....
Old 11-07-2008, 08:06 PM
JrummerJ JrummerJ is offline
HFS is mac format. Specifically, it should be HFS+ Journaled.
J
No playback after I recorded..... mingalls Pro Tools HDX & HD Native Systems (Mac) 0 08-10-2012 06:18 AM
Fuzzy\distorted playback of recorded audio. Caatalyst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-04-2011 03:19 PM
Do not understand how to get recorded audio to playback, need help. Boots Pro Tools M-Powered (Win) 2 12-16-2010 11:46 PM
No sound on recorded playback. tfee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-16-2008 04:08 PM
Distortion in playback on recorded audio LACrusaders 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2005 10:49 AM
