Old 06-29-2001, 09:14 AM
barden barden is offline
Default 5.1.1 Import Audio Dialog - another change?
Hello All...
After finally getting used to using Command-Spacebar to audition within the Import Audio window in 5.1 (a change from just plain ol' Spacebar in every other version prior...), I have just installed 5.1.1 and now cannot audition with the Spacebar at all (regardless of key combo). Command-P is the only one that seems to do anything.
Anybody else experiencing this?
All the best,
Barden
Sound Dogs
Old 06-29-2001, 02:35 PM
The Recordist The Recordist is offline
Default Re: 5.1.1 Import Audio Dialog - another change?
I just upgraded as well and command-spacebar works fine for auditioning at import on my system. Check your Keyboard control panel. Sometime opening up the control panel resets the keyboard. Just a thought. also try zapping the P-Ram
-Frank
Searching in Import Audio Dialog Submersible Pro Tools TDM Systems (Mac) 2 05-20-2007 01:22 PM
I cant preview audio in digibase or import audio dialog. sammyfarr Pro Tools TDM Systems (Mac) 0 03-29-2007 01:16 AM
Small "import audio" dialog bug? thierryd Pro Tools TDM Systems (Mac) 0 12-10-2006 04:24 PM
Import Audio dialog , Can't select or play audio Irl Sanders Pro Tools TDM Systems (Mac) 11 10-04-2006 02:02 PM
Import Audio dialog PROBLEM jimlongo Pro Tools TDM Systems (Mac) 1 03-12-2001 03:32 PM
