Old 01-15-2007, 06:55 AM
crizdee's Avatar
crizdee crizdee is offline
Default No playback loop with midi track in record SORTED!
Had quick punch enabled must of hit it by mistake!!! so sorted?
Just came across this problem. when a midi track is record enabled, you can't get the playback to loop? very frustrating having to keep putting the track out of record to get playback to loop!!
Have i missed a new feature or pref of 7.3 somewhere?
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-15-2007, 07:35 AM
mhmh mhmh is offline
Default Re: No playback loop with midi track in record
Works fine here. I should know since my MIDI Tracks are in record mode most of the time.
Martin
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0
http://www.pelhamundhaas.de/index2.html
http://www.pelhamundhaas.de/vita.html
www.3-p.de
www.imglashaus.de
Old 01-15-2007, 08:37 AM
tj_davies tj_davies is offline
No problem here. Try the usual trash preferences etc. procedure.
Hope it solves your problem!
Timothy
G5 10.13.6
PT Ultimate 2019.12.0
www.pearls-music.com
Loop playback with record enabled MIDI tracks fm_xtk Pro Tools TDM Systems (Mac) 2 07-04-2009 01:30 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
MIDI INST TRACK/RECORD WHILE PLAYING LOOP 7.1 LE AKELCO MIDI 2 06-17-2006 10:59 AM
Playback during Loop Record? Mr. Bojangles Tips & Tricks 1 11-27-2000 04:01 PM
