Old 11-05-2004, 08:12 PM
dlae dlae is offline
Default ...need some help with ableton live as PT LE slave
I'm just starting out, bit stuck
I'm sure its a simple enough process, i just can't see it...
i'm trying to figure out how to use ableton live as slave with protools
i have live as insert in protools track, track is record enabled, i can see the levels and hear the sound, but as soon as I try to record it on that track the sound dissapears and i record silence
what am i doing wrong?
...thank you
dlae
Old 11-06-2004, 08:17 AM
guitarmongoose guitarmongoose is offline
Default Re: ...need some help with ableton live as PT LE slave
All plug-ins, including rewire ones, operate post fader, meanng that they have an effect on playback but don't record. In order to record live, or any other plug, you need to route the output of the Live track to an empty audio track and record it there.
Say you have an aux or audio track with the live Plug and set the output to anyavailable bus pair. Create a new audio track and set the input of that track to the same bus as the output of the live track. Record enable the audio track and record and it should work.
Brad Semenoff
Sound Editor
Old 11-07-2004, 04:56 AM
thank you very much, guitarmongoose.
i finally figured it out, by selecting time in the live track and bouncing to disc.
but now i will try to do what you suggested.
Old 11-08-2004, 04:03 AM
JFreak's Avatar
JFreak JFreak is offline
no. they operate post-input which means plugins are not recorded.
after input comes the plugins, then comes the sends that have set to pre-fader operation, then the fader, and last one are the sends that have been setup to work as post-fader (default).
if plugins were post-fader, plugins would not affect to sends. they do, so there you go...
Janne
Ableton Live rewire slave into PT workflow vudoo Pro Tools TDM Systems (Mac) 5 10-18-2015 05:33 PM
playing live, ableton live best option? shabbar3 Pro Tools 9 0 07-11-2013 05:22 PM
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
Ableton Live 2.1 as Rewire Slave in Pro Tools 6.1??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-29-2003 03:36 PM
Ableton live as a ReWire slave in PT6.1? EvenAce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-28-2003 07:06 AM
