Old 03-01-2009, 03:15 PM
basslik's Avatar
basslik basslik is offline
Default Master mixdown
Can someone direct me to a video tutorial how to mix down to a stereo bus, then master please?
Old 03-01-2009, 03:59 PM
AlexLakis AlexLakis is offline
Default Re: Master mixdown
www.vikingkittens.com
Old 03-01-2009, 04:38 PM
JMS40 JMS40 is offline
Hi basslik-
Simple question to ask, not so simple to answer.
Understand, both mixing and mastering are college level degree equivalents, so no single video tutorial is going to apply here.
Maybe if we knew a little better where you're actually starting from it would help.
Do you have any experience with either or are we starting from scratch?
Where are you at as far as the basics in Pro Tools?
Know how to add a master track... understand Bounce to Disk... etc.?
Understand panning... use of effects and routing?
Old 03-01-2009, 05:14 PM
basslik's Avatar
Originally Posted by JMS40 View Post
Hi basslik-
thank jms40, yea i just started learning this pup, i have the song tracked, i did do a rough bounce to disc, but was wondering if there should be a mix down stereo sub, the apply a mastering plugin along with a dither?
Old 03-01-2009, 05:59 PM
My advice for those new to mastering is; go lightly. In other words, small steps with small adjustments as you learn so you don't throw a bunch of plugins on and dig a hole for yourself. First thing is to play the mix over a few different systems before making any adjustments(try to see what is wrong on ALL the systems vs. correcting for 1 system and finding that doesn;t work for the others). At first I would stick to very gentle EQ and gentle mastering limiter(if you are sending the project to be mastered, don't do anything). If you recorded at 24 bit, your dither plugin should be the last insert(if the project is at 16 bit, then there is no need for dither). If your gentle treatment doesn't get the music where you want, I would remix and get the mix closer to where it needs to go. Mastering by a seasoned mastering engineer can do wonders but in the hands of the rest of us(I include myself here even after 20+ years of mixing).....you get the idea.
BTW, FWIW, I usually bounce with no master fader or plugins and then import the stereo file into a mastering session for the final treatment(which includes trimming the front and tail and creating a fadeout if needed).
Old 03-01-2009, 07:03 PM
Mikeymike Mikeymike is offline
How do you mix down to a stereo audio track?
Old 03-01-2009, 07:34 PM
basslik's Avatar
thank you albee1952, give it a try.
Old 03-01-2009, 08:20 PM
Easiest way is to Bounce to Disk, and choose Stereo Interleaved in the first options box that comes up. I usually bounce to the desktop(the default is to the audio files folder for the session you have open). Don't be tempted to cheat and bounce a 24 bit session to a 16 bit file without dither. I bounce my 24 bit sessions to a 24 bit file and import the stereo mix track into a new session and trim the head and tail, and add a fadeout if needed(I know its an extra step but I like to keep the mix as a step all by itself. Each of us must define our ideal working methods).
You could also choose to set all track outputs to a stereo buss(holding the Alt key while setting any single track's output will change them all). Then create a new stereo audio track and set its input to the bus you sent the test of the tracks to. Put the new track in record and roll the song. Once its done, you can export the new region(track) as a stereo audio file.
Old 03-02-2009, 03:22 AM
The latter was what I was after. Thanks. I had read that you can put an insert on the Master Fader and bus it to a stereo audio track, mute the track, record the mix, and export the file, but there are no inserts on the Master Fader. I thought of doing it how you suggested, but I wanted see if there was a way to do it without changing the output on all the tracks. Thanks for the help.
Old 03-02-2009, 08:15 PM
basslik's Avatar
right on guys, so many ways i guess?, will try different things, no rules right?
Master fader over loaded on mixdown converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-31-2009 10:30 AM
master fader mixdown jhammer619 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-03-2008 02:50 AM
Plugins on Master Fader or Main Mixdown Track studioslave77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-20-2007 12:02 PM
Mixdown - mixdown pitch shift problem kakeneeditoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-03-2007 03:38 PM
What are you using on your master fader during mixdown? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-03-2001 06:45 AM
