Maximum length for Adat Light Pipe ? Anyone.
Do any of you have a clue. Also. What about optical s/pdif?
Rating of the single mode fiber? Are these diode generated pulses? Thanks,
"The original nipper" Throw me a bone (Telefunken DI is ok too) |
Re: Maximum length for Adat Light Pipe ? Anyone.
Lightpipe's maximum length is 10 meters according to the spec. I don't know the max length for Toslink (optical S/PDIF). It's probably about the same.
Are you sure that they're single mode? I would think it's a multimode cable. Usually single mode is used only for longer distances (such as km or miles). Don't know the rating, but it's 1mm plastic fiber. LEDs produce visible red light for S/PDIF, and it LOOKS red coming out the ADAT interface. You ask tough questions, Shag.... Are ya building an optical converter or what? ------------------ LW
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
No Larry. It was this Eagle catalog that gave me the idea.
Tascam's new DA 78 w/ lightpipe card. Keeping the mic cables short and the A/D's near the pres....but ten feet? That is down right deflating.
uh, 10 METERS = 33 feet
I don't think that's a serious limitation. ------------------ LW
Did I say ten feet? Anyhow. You still think this is multi mode?
Maybe a little extra spit on the polish would get me the distance (I was thinking along the lines of 802.2 or something) Where are those cold war widgets when you need em?
Adat Light Pipe | VincePro | Pro Tools TDM Systems (Mac) | 3 | 11-23-2005 03:42 AM |
Audible clicks via ADAT light pipe | Bilborun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-20-2003 07:48 AM |
Adat light pipe for 002r | PBJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-27-2003 09:29 PM |
Adat light pipe in ? | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-13-2001 12:06 AM |
Problem with 001 and Adat light pipe | bluesna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-08-2001 03:50 AM |
