Old 04-12-2022, 03:08 PM
Schottlandru Schottlandru is offline
Default Custom plugin map / multi-mono / jumps to L channel every time
Hello,
I am currently surprised by custom plugin maps on a multi channel aux.
On my Dia aux, I configured a map for a multi-mono plugin.
I want to have Center selected to see the processing.
Every time I touch a fader (plugin map), it switches back to showing L (left channel).
Anybody else seeing this?
I remember this working a while back though (old plugin expand maps).
Thanks for any ideas!!
Andrew
Old 04-12-2022, 03:34 PM
creativecontrol's Avatar
Default Re: Custom plugin map / multi-mono / jumps to L channel every time
Greetings,
The controls work, the identification of the correct leg for the automatic display of the window does not.
Here's the current functionality:
The last page of the chosen Insert Parameter maps (teal) should include the current channel and then MltiMono.
Use the encoder to choose the channel (L, C, R...)
Use the Sel switch to Unlink all
When unlinked, use the In switch to link individual channels for linked control - such as L, C, R.
If you open all legs and de-target you will see the functionality. I'll defer to Eddie on getting intelligence for Pro Tools to automatically choose the correct leg on encoder touch.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 04-14-2022, 08:01 AM
DAPG DAPG is offline
I'm having the same issue as Andrew and I posted about it a while back. If I control the center channel of a multichannel plugin, the plugin's window shows the left channel regardless of the channel I am controlling with the S6. This is a major workflow killer. Please, please fix this soon! Thanks!
Roy Machado
Dallas Audio Post
Old 04-14-2022, 04:17 PM
Understood. Yes, Eddie is aware of the issue. Hopefully we can get it sorted sooner than later.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-25-2023, 07:51 AM
Checking on progress on this issue. Can we expect a fix soon?
Roy Machado
Dallas Audio Post
Old 03-03-2023, 06:38 AM
Gregor B. Gregor B. is offline
This is also an issue when working in linked mode:
Let's say I am working on a 5.0 dialog aux, manually choose to view the C leg on a compressor (because thats where signal is coming through 90% of the time) and unclick the red target button of the window so I always view it.
Now whenever I click the compressor on S6 to change its parameters on S6 it will open that window AGAIN, but this time with the standard left leg, covering the existing window that I would need to see. This is a strange behavior, because why would it open one plugin twice and not just bring the existing window to front while leaving the leg untouched...
Old 03-03-2023, 07:38 AM
Yes, understood completely. I'll defer to Eddie on any timeframes for improved functionality.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-03-2023, 09:42 AM
BScout BScout is offline
Just to be clear, are you saying that there are two plugin windows open for the same plugin (same insert slot) at the same time? I did not think that was even possible for Pro Tools.
Old 03-03-2023, 12:27 PM
correct!
Old 03-03-2023, 02:27 PM
That seems like a _much_ bigger problem that needs to be addressed from Pro Tools and not Eucon. It's a complete break in the paradigm which is clearly a bug.
Can only see L channel in 5.1 Multi Mono plugin Benny Mouthon Pro Tools 2020 6 10-26-2020 02:14 PM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
multi-mono versus mulit-channel plugin pietro79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2007 02:33 PM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
