Old 07-06-2021, 10:27 AM
quangaroo quangaroo is offline
Default Export vs Bounce -- Volume Differences?
Hi--
I use PT 2019 for recording voiceover -- almost always mono tracks with little to no processing, sometimes some normalizing. On occasion, I've found a clip/region that I've exported to mp3 has a lower volume than the way it plays back in the timeline. If I adjust the gain on the clip and export it again, nothing sounds like it changed. But if I bounce it to disk, then I'll here the volume/gain change.
This is not a consistent phenomenon, but it happens enough to make me wonder if I'm not inadvertently doing something to cause it.
Any thoughts?
Mac Pro 5,1 (Mid 2012) | macOS 10.13.6 | 48GB RAM // Pro Tools 2019.5.0 | Digi 003 Rack | Digi 003 Rack+
Old 07-06-2021, 11:27 AM
Default Re: Export vs Bounce -- Volume Differences?
Export does not include any volume automation or setting and AFAIK, does not include CLIP GAIN unless you render it. Your best practice is to bounce(especially if you are sending to someone for approval)
Old 07-06-2021, 12:20 PM
Thanks for the heads up! I was not aware that the clip gain change was not applied in the export unless you rendered it (or bounced it).
Question: If I merge multiple regions before exporting them from the timeline, is that considered a render, and will it carry over any clip gain adjustments made prior to the merge?
Old 07-06-2021, 12:55 PM
Ben Jenssen's Avatar
Originally Posted by quangaroo View Post
Thanks for the heads up! I was not aware the the clip gain change was not applied in the export unless you rendered it (or bounced it).
Yes.
In PT it's called 'consolidate'.
Select anything, including empty space, hit cmd-shift-C, and there is a new clip on the timeline, and a new wav in the audio files folder and bin, and it includes clip gain.
Old 07-06-2021, 01:51 PM
Originally Posted by Ben Jenssen View Post
Yes.
Thanks Ben!
BTW, I'm on a Mac and have been using Option+Shift+3 to consolidate (it shows that combo in my dropdown menu as well). When I tried cmd+shift+c, nothing seemed to happen. Is that for a different version of PT or for Windows?
Old 07-06-2021, 01:54 PM
Thanks Ben!
Sorry, my mistake. Momentary lapse of… something.
Old 07-06-2021, 02:00 PM
No worries -- thank you! This thread has cleared up a lot for me :)
Old 07-07-2021, 06:39 AM
Another option is to COMMIT the entire track(this would include all plugin processing you might have on the track, like EQ or compression)
Old 07-19-2021, 04:00 AM
Yet another option is to just record (in real time) the whole shebang to another track. No need for export or bounce. Then send that track to whomever needs it. That's IF the other party will accept a regular .wav file.
Jack
QAPLA!
Old 07-19-2021, 04:54 AM
JFreak's Avatar
JFreak JFreak is offline
That is just like bounce in realtime, but you can see the waveform building while it records. Both can be canceled when you hear something disturbing. Only pointing out that the advantage of this method is you can do it whenever wherever, like printing a 2-track of drum kit while you record it, with your fader movements.
Janne
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 andresix Pro Tools 13 11-19-2021 07:03 PM
Bounce Issues - +6-8db added after bounce/ export brybedo Avid Pro Mixing General Discussion 2 12-24-2019 09:33 AM
HD vs Native differences in mixdown-bounce zavid Pro Tools 12 23 04-24-2017 03:42 AM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 05:58 PM
Pitch Shift causing volume differences 71stars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-07-2009 03:56 PM
