Old 01-12-2017, 02:29 PM
marcnyc marcnyc is offline
Default how to enable HEAT
I just downloaded the Heat 10.2 installer because I wanted to give it a try.
I am on pro tools HD 12.6.0 but I can't find where to enable HEAT. The manual seems to be referring to old versions of pro tools and the installer doesn't come with a read me... any ideas?
Old 01-12-2017, 02:38 PM
priorytools priorytools is offline
Default Re: how to enable HEAT
Hhmm, I have a feeling it comes included with PT 6 x…
Search it in the PT ref guide.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 01-12-2017, 02:41 PM
LDS LDS is offline
You can usually find the most recent version of Heat hiding in a folder of your Pro Tools installation file that you have downloaded from Avid. I get the impression Heat 10.2 may be a version for Protools HD 10.
You will also need an iLok license, either a complete license or a demo license to use Heat. From there, you activated it using one of the dropdown menus on the application task bar at the top of the screen. From memory, it is hiding in the same dropdown menu as disabling/enabling delay compensation.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 01-12-2017, 03:01 PM
jeffro's Avatar
jeffro jeffro is offline
HEAT isn't installed separately since 11.0 was released. I just cleaned up the HEAT KB to clarify this.
linkedin
Old 01-12-2017, 03:14 PM
Interesting... I just downloaded the Heat 10.2 installer from Avid.com and that was the most recent number I saw...
either way, even after reading the Heat KB, I still don't know how to activate it... I requested a demo license and got one, but I don't see Heat anywhere or even a button to enable it in the preferences...
Old 01-12-2017, 03:23 PM
jeffro's Avatar
You should remove HEAT 10.2.
Check out Chapter 46 (pg 963) in the PT 12.6 Ref Guide for info about using HEAT.
linkedin
Old 01-12-2017, 03:26 PM
jeffro's Avatar
Also... I see you downloaded the HEAT license to your iLok account but it shows you haven't activated it to your iLok (that contains the HD license bundle) yet.
linkedin
Old 01-12-2017, 03:30 PM
I've removed the plugin.
Now I am looking at the PT 12.6 reference guide and it says:
To enable (or disable) HEAT in a session, do one of
the following:
 Select (or deselect) Options > Activate HEAT.
...but I don't see this option anywhere!!!!
 Select (or deselect) the HEAT On/Off button in
the Mix window in HEAT view.
You can also enable the Enable HEAT in New Sessions
option in the Pro Tools Preferences to have
HEAT automatically enabled for all new sessions.
To enable (or disable) HEAT for new sessions:
1 Choose Setup > Preferences.
2 Click the Processing tab.
3 In the DSP Management section, select (or deselect)
the Enable HEAT in New Sessions option.
...but here is no DSP Management section!!!
4 Click OK.
Please see attachments
File Type: png Screen Shot 2017-01-12 at 6.31.04 PM.png (90.5 KB, 0 views)
File Type: jpg Screen Shot 2017-01-12 at 6.30.55 PM.jpg (19.5 KB, 0 views)
Old 01-12-2017, 03:31 PM
jeffro's Avatar
Looks like we were posting at the same time... you need to activate the HEAT license to your iLok.
linkedin
Old 01-12-2017, 03:32 PM
oh that's the missing link!
ok thanks...
last question: do the 30 days start from when I activate the demo license or from when I requested the demo?
Where is the HEAT ronstephens Pro Tools 11 13 07-02-2015 09:16 AM
HEAT Mark Dann Buy & Sell 0 04-22-2015 10:32 AM
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
FS: Heat TDM Simonluka Buy & Sell 0 01-24-2014 12:08 PM
re heat on 10 2224 macOS 9 08-12-2012 05:11 PM
