Old 03-01-2010, 11:21 AM
Bangha Bangha is offline
Default Standard White MacBook
Hey everyone, Im in a real hurry here. One of my editors PC's just died on me and I need to get em back up and running immediately. Will the standard 2.26 2GB white macbook do the trick with PTLE 8?
I apologize for not searching over the whole duc, but deadline is REALLY fast approaching and I must get my hands on the substitute machine now, as I mix.
thanks!
Old 03-01-2010, 11:47 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Standard White MacBook
What interface? Does the white have FW and USB? You could use a USB interface and FW external drive. What OS on the MacBook?
Give us some info, please!!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 03-01-2010, 11:48 AM
JazzyJ JazzyJ is offline
If the Macbook has a FIREWIRE port then Yes - you can use Mbox Pro, Digi 002 etc or use Mbox2 USB with a Firewire Audio Drive.
If the Macbook DOESN'T have a FIREWIRE port then you can't use a Firewire Drive for Audio and so the system is not Digidesign Supported.
As far as I'm aware, the new Macbook's don't have a Firewire port - Only Macbook Pro's.
If you can get an older / second hand Macbook with a Firewire Port then you're in business.....
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 03-01-2010, 11:56 AM
Nope, grrr no FW, just USB, however I have had luck running sessions off a USB drive with my MBP on a few ocassions. Anyone have any experience at all with the late 2009 MB? OS wise it snow leopard, but im running that station with an mbox original so id have to downgrade to leopard.
Old 03-01-2010, 04:55 PM
Sorry, that is just not a good combination for Protools. I'm not saying that there is no way it will work but you may be headed for a lot of frustration. Here are your problem areas: (USB drive for your Audio sessions, Snow Leopard with Mbox1). I know you are considering downgrading the OS to Leopard but that is not necessarily as easy as it sounds. What version of Protools 8 are you trying to run?
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6 running Protools 2021.7
FW with Macbook White and Mbox 3Pro Mahkyb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-24-2012 11:00 AM
6 GB Ram in white macbook boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-12-2009 10:31 AM
White Macbook Soma Spiral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-05-2009 02:10 PM
Powerbook G4 vs White 2ghz Macbook DustySpuds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-04-2007 08:08 AM
Avid 888 (white face) same as standard 888? ClickRec Pro Tools TDM Systems (Mac) 2 11-08-2003 11:08 PM
