Old 09-12-2024, 09:23 AM
zavid zavid is offline
Default Pro Tools HD Pci-x & Mix Pci Cards On Mac G5 Pci
Hi all,
looking for info about compatibility
of Pro Tools HD Pci-x and Pro Tools Mix cards
with old Mac G5 models with Pci slots
(the G5 models with only Pci slots are 3),
it is possible install Pro Tools Mix Tdm cards,
and the Pro Tools Pci-Pci-x HD cards?
Where is possible get info about?
Here the specs about G5 models:
Single 1,8 Ghz Cpu:
https://everymac.com/systems/apple/p..._g5_1.8_2.html
Dual 1,8 Ghz Cpu:
https://everymac.com/systems/apple/p..._1.8_dp_2.html
Dual 2,0 Ghz Cpu:
https://everymac.com/systems/apple/p....0_dp_pci.html
Old 12-01-2024, 07:01 AM
groovebrother groovebrother is offline
Default Re: Pro Tools HD Pci-x & Mix Pci Cards On Mac G5 Pci
hello, nope you had to choose between the two.
LIVE : All Rough Mixes ...
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4 / 8 / PT 11 (non hd)
Old 12-04-2024, 10:54 AM
Thanks for the post,
and sorry if asked not clearly,
the question is if the 3 model of G5 computers with pci slots,
work / are compatible with both of pro tools cards type,
obviously not together inside the same computer,
thanks.
Mac 12 Core + 2 Hdx Cards + Magma Digi Rev B + 3 Uad Octo Cards + Pro Tools 12.8.3 drago76 Pro Tools 12 2 12-19-2019 09:38 PM
FS Pro Tools HD Cards Raoul23 Buy & Sell 5 04-26-2018 09:50 AM
Pro Tools 10 + 4 PCI HD cards + Mac OS X 10.8.2 vadimlisa macOS 0 12-13-2012 12:10 AM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
UAD-1 DSP Cards and Pro Tools? JoeRocks123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-23-2010 12:52 PM
