I haven't been able to find a solution to the EUCON error for months
The error was the same when I updated to Windows 11, and I tried to fix it through the method that I presented continuously, but it didn't solve the problem at all. The log looks like this.
======== HSL logging started at Thu Jun 27 18:27:52 2024 ======== HSL enabled logging of category 3 (via internal HSL default) HSL enabled logging of category 4 (via internal HSL default) HSL enabled logging of category 5 (via internal HSL default) HSL enabled logging of category 6 (via internal HSL default) 1 18:27:52.778590 (0000.000000) INFO [Main ] EuControl Windows starting up 2 18:27:53.033205 (0000.254615) INFO [Main ] Crashpad error reporting enabled 3 18:27:53.033617 (0000.000411) INFO [Main ] OS: Windows 10 10.0.19041.3636 4 18:27:53.033621 (0000.000004) INFO [Main ] App Architecture: Intel 64-bit 5 18:27:53.066280 (0000.032658) INFO [Main ] EuControl version 2023.11.0.121 6 18:27:56.156691 (0003.090411) INFO [Main ] trying to start DOF comms... 7 18:27:56.158565 (0000.001873) INFO [Main ] Network Configuration at Startup... 8 18:27:56.158566 (0000.000000) INFO [Main ] ------ Index 6 Mac: IP Mask 255.255.255.0 Intel(R) I211 Gigabit Network Connection 9 18:27:56.162011 (0000.003444) INFO [Main ] External workstations are DISABLED 10 18:27:56.162020 (0000.000009) INFO [Main ] EUCON NIC set to "" index 0 in EUCON preferences 11 18:27:56.162026 (0000.000005) INFO [Main ] Creating BonjORB instance 12 18:27:56.173973 (0000.011947) INFO [Main ] Resetting BonjORB interface to index -1 13 18:27:56.174095 (0000.000121) INFO [Main ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\bonjorb.cpp:358 BonjORB interface reset to use ANY interface index and Local Loopback IP Address 14 18:27:56.175406 (0000.001311) INFO [Main ] Using EuControl UNICAST meter address 127.0.0.1 15 18:27:56.175637 (0000.000231) INFO [Main ] EUCON adopting EuControl's HSLLogManager 16 18:27:56.176626 (0000.000988) WARN [Main ] | DEADLOCK DETECTION in EUCON is disabled 17 18:27:56.180582 (0000.003956) INFO [Main ] | Starting EUCON version 4.17.2.121 (EuCon 4.17.2) Intel 64-bit 18 18:27:56.181245 (0000.000663) INFO [Main ] | bonjorb.cpp(188) BonjORB CreateWithFilter called on existing instance, new filter is ignored 19 18:27:56.182343 (0000.001097) INFO [Main ] | bonjorb.cpp(358) BonjORB interface reset to use ANY interface index and Local Loopback IP Address 20 18:27:56.182597 (0000.000253) INFO [Main ] Start BonjORB browsing 21 18:27:56.182624 (0000.000027) INFO [Main ] Create DOF MC2 instance 22 18:27:56.182651 (0000.000026) INFO [Main ] [[SCN1]] SERVERMODULE 0000000003A88498 BEING CREATED, NEW TOTAL: 1 23 18:27:56.184716 (0000.002064) ERROR [Thread 0x431c ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\eudofdnsservices.cpp:94 DNS Services error: Bad Parameter 24 18:27:56.184725 (0000.000009) ERROR [Thread 0x431c ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\bonjour \source\eudnsservices.cpp:1420 RemoveServiceRef - null ref pointer, or parent service 25 18:27:56.186551 (0000.001826) ERROR [Thread 0x431c ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\eudofdnsservices.cpp:94 DNS Services error: Bad Parameter 26 18:27:56.186557 (0000.000005) ERROR [Thread 0x431c ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\bonjour \source\eudnsservices.cpp:1420 RemoveServiceRef - null ref pointer, or parent service 27 18:27:56.188313 (0000.001755) ERROR [Thread 0x431c ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\eudof\f ramework\eudofdnsservices.cpp:90 DNS Services error: Bad Parameter, msg: error in registerServiceWithBonjour:{EuNetService - this:0000000003A8A2D0, domain:, type:_EuDOF-._tcp., name:EUCON_MC EuControl AE-A9-EF-B4-00-00 8044, hostName:, NIC:0} 28 18:27:56.188317 (0000.000004) ERROR [Thread 0x431c ] d:\ws\eucon\release\2023\23.r1.1\cs\shared\bonjour \source\eudnsservices.cpp:1420 RemoveServiceRef - null ref pointer, or parent service The MAC address is self-obscured for security. What's the solution? |
Re: I haven't been able to find a solution to the EUCON error for months
Best to start up a support case if you have an active Pro Tools support plan or subscription so this can be further investigated.
Might be a compato issue. note that only intel processors are supported on windows at the moment.
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Your network adapter is not reporting an IP address? Check your network settings. Then do this. Uninstall EUCON using the installer, check remove all Apps and Remove all prefs. Then go to Windows settings and uninstall Bonjour. Restart and install EuControl again(which will also install the correct Bonjour version)
Solution To Strange Performance Issue with Eucon 3.1.2 | AlienArtist | Artist Series | 4 | 09-04-2014 07:28 PM |
EUCON 2_6_1 eucon discovery cant find ip | klaukholm | System 5 | 2 | 10-22-2011 12:01 PM |
after months...pro tools can't find mbox | doug skillmore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-15-2011 10:46 PM |
DAE error message I haven't seen before.. | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-19-2003 12:54 AM |
PTLE 5.0.1 : a month, 2 months, 6 months, a year? | Kickin.da.speaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-11-2000 06:51 AM |
