Selecting Eucon In Protools Crashes Protools
Hi all, this one has me absolutely stuck.
I have been using ProTools 2024.3 Ultimate with Eucon 2023.11 for sometime. However, now when I select Eucon in the ProTools session window, it crashes ProTools. Yes, I have uninstalled and reinstalled Eucon, updated ProTools to the latest software bypassed the ethernet switch and it’s displaying the same fault. I've updated to PT 2024.6. Hardware: S1 x2>Netgear switch>CALDIGIT TS3plus>TB>MBP M1max The switch carries my internet connection to the CalDigit as well, this has not been a problem. I've used What I’ve never encountered is it displays the same fault with two different versions of Protools. Any help would be warmly welcomed. Thank you so much! Jamie. Last edited by SOS Sydney; 06-24-2024 at 11:13 PM. |
Re: Selecting Eucon In Protools Crashes Protools
Is this without any session loaded? What about a new blank session? When you uninstalled EUCON did you use the installer and check remove all Apps and remove All prefs? Mac or PC?
I've found that in 24.6 when you have Altiverb XL 8 in your session and you enable Eucon (in the open session)PT will crash with a hard-crash and reporter window saying that AV8 has crashed.
The only way to enable Eucon is to first move AV8 AAX out of the plugins folder, start PT, open session, enable Eucon (which then works fine), save, quit. Put plugin back into plugins folder. And re-launch PT and session. Now since the session opens with EC already enabled you should be fine. Frank
PTHDnPCIe 2024.6 (OSX13.6.7), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Protools 12.5.2 repeatable crash when selecting midi region | Stereo Missile | Pro Tools 12 | 28 | 04-07-2019 08:50 AM |
Protools crash when selecting focus track | WinterMute16 | Avid S1, S3, Dock and Control App | 0 | 02-02-2017 04:09 PM |
Need advice in selecting a new laptop to go with the elevenrack+protools 11 bundle | Interlock | Eleven Rack | 6 | 12-03-2014 08:17 AM |
HELP - Protools LE 7.3 crashes when selecting MBOX 2 Output | revola | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-17-2008 09:16 PM |
selecting korg N5ex drumbank from within protools | otto | MIDI | 4 | 03-06-2001 06:04 AM |
