Old 02-25-2010, 12:10 PM
Chris Nelson Chris Nelson is offline
Default Anyway to have plugin window BEHIND Mix or Edit Windows
Title says it all.
Is it possible to have a plug in window OPEN behind the MIX or EDIT windows. This is what I want to do:
Open a plug-in that uses a lot of the screen real estate. I want to position it on the far bottom of the screen so I can see the dBfs meter within the plug-in. Then I want to move the EDIT window OVERTOP most of the plug in. But since it seems like plug-in windows are always on top i can't get this to work. Any thoughts PT users?
Or if anyone can send me a link to a *free* version of the dynamic range meter I wouldn't need to bother with this!
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
How to: Switch between sub-windows: Midi editor inside of edit window bashville macOS 3 10-20-2012 07:59 PM
PTHD for Windows -- bizarre Edit Window behavior jjnyc Pro Tools TDM Systems (Win) 4 12-09-2007 06:53 PM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
Sampler plugin with Drag & Drop from edit window?? goldn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2003 04:04 PM
