trying to change the save location
I'm trying to change the location for audio files that I normalize. It seems the program automatically saves them to my main hard drive -- but I want to change that to save it on my external hard drive in a specific location. I went to preferences, but I can't seem to find any way to change the save location. I have a Mac OS X, LE 6.9.2. Thanks! Garrett Fisher |
Re: trying to change the save location
Files processed with audiosuite will automatically be created wherever the disk allocation for that track is set. You should visit that window before you run your processes and set them to the place you want to save them.
Good luck. |
go to - set ups>disc allocation and set the disk and folder where you want to save to - ideally do this prior to starting any work, and save this set up as part of your "session template". Then ideally, each time you open that template to start a session, your disc save allocation will be to the correct disc.
You can check that files are going to the correct location by having the "Project" window open whilst you work, and checking the disc allocation from there.
www.kitestudio.co.uk Mac Pro Snow Leopard 003 & Midas Venice desk Mindprint DTC Soundelux U99 Drawmer M-Clock |
Help: PT not remembering last save location | Studio Dweller | Pro Tools TDM Systems (Mac) | 1 | 05-20-2008 03:54 PM |
Should I change the location of samples for AIR instruments? | EvilElfBoy | Virtual Instruments | 1 | 03-27-2007 09:32 PM |
Problem with audio file save location | milet22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-14-2005 01:28 PM |
Change the RTZ location | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-19-2003 08:06 AM |
How do I change the order of selections in Memory Location ??? | dw | Tips & Tricks | 3 | 03-29-2000 05:00 AM |
