  #21
Old 03-27-2023, 08:32 PM
mrguitarguy mrguitarguy is offline
Default Re: M2 Pro Mini vs M1 Studio Max
Originally Posted by mike661 View Post
I'm just here to report that I own both Mac Studio M1 Max and Mac Mini M2 Pro 12 core.
This past week I just replaced 4x Mac Pro 7,1 (2019) 12 and 16 core machines with the Mac Mini M2 Pro 12c, 1TB, 32GB. The Sonnet DuoModo xMac mini/Echo III (rack and desktop versions). I'm running both HDX and HD Native PCIe options with UAD-2 Octo PCIe and Sonnet 10G ethernet cards.
They are what I've observed slightly faster than the M1 Max in their responsiveness and plugin count/cpu performance. Pro Tools only address the 8 performance cores.
These machines have been 100% solid. We've extensively run PT in both Rosetta mode and Apple Silicon mode, depending on the session requirements. I can't say there's a noticeable difference in either mode.
The Mac Pros we replaced were MUCH more capable as far as CPU/plugin power. I will miss them, but I wanted out as the future of Intel supported Mac is clearly going to get worse as time marches forward.
Thanks Mike! That's great info! Have you run into any issues with your HD Native card? Was it a simple setup? Any hoops to jump through?
Big Sur 11.7.4, Pro Tools Ultimate 2023.6, HD Native, 2010 Mac Pro 5,1 3.46ghz 12 core, 128GB RAM, Radeon RX 580, 970 Evo M.2, 860 Evo, and Angelbird SSD drives. All PT optimizations followed to the letter.
Ventura 13.2.1, Pro Tools Ultimate 2023.9, M2 Pro Mac mini, 32GB RAM, 1TB SSD.
  #22
Old 03-28-2023, 07:31 AM
mike661 mike661 is offline
The only issue whatsoever was when the Native card was in the chassis without the HDX switch flipped (position 2, I believe) the card would drop out signal to the converters after about 15 minutes. So, although the Native card is not and HDX card, the chassis must be set as though it is.
  #23
Old 03-29-2023, 12:09 AM
chaos audio chaos audio is offline
Does this mean that the HD Native PCI card works properly with an M2 Mac Mini and a Sonnet EchoIII?
N.
PT Ultimate 2023.6, HD NATIV PCIe,
MacStudio Max, Sonnet EchoIIID, MTRX Studio, 2x192, UAD2 Quad, Sonnet Fusion SSD Raid, Dolby Atmos 7.1.4,
Mac OS 13.1.
  #24
Old 03-30-2023, 07:21 PM
N.
Absolutely. Both HDX and HD Native are 100% successful on all of our Mac Mini M2 Pro, Mac Studio M1 Max and Ultra, only by using the Sonnet Echo III (not the Echo Express III-D).
  #25
Old 04-07-2023, 04:14 PM
arche3's Avatar
arche3 arche3 is offline
I’m about to try the Mac mini M2 pro. I’m currently on a 7.1 16 core. Hdx2. I thought the M2 pro Mac mini would give more plug-in power than the 7.1 Mac pros. So did you find the Mac Pro 7.1 out performs the m2 pro minis in terms of protools plug-in power and cpu headroom currently? Thanks.
  #26
Old 06-12-2023, 11:32 AM
mkerner129 mkerner129 is offline
I have an iMac Pro and switched to a M2 Pro and I'm not super happy with the performance. It doesn't seem any better than the iMac Pro. Has anyone else seen differently?
Apple Studio/Mini - What bits we need kings79 macOS 73 05-17-2022 12:15 AM
Will this Mac Mini do the job in my producer studio? purplepurplepurple General Discussion 4 04-28-2019 02:13 AM
Blackmagic Ultra Studio Mini Monitor Goombot Pro Tools 12 1 04-21-2016 08:17 PM
Help regarding Avid Recording Studio & Mbox mini HK44 Pro Tools M-Powered (Win) 1 03-29-2011 07:00 AM
002 MINI STUDIO - specs and price mman00 Pro Tools TDM Systems (Mac) 6 07-18-2002 12:15 AM
