Old 04-05-2011, 06:45 PM
georgeski georgeski is offline
Default usb 2 hard drive for pro tools 9 use
Hi everybody,
I'm new to this group and am coming up to speed with pro tools 9 in a Digi003 environment. I run win 7. I'm looking for a good external hard drive for audio data that runs at 7200 RPM and uses USB 2.0 as it's interface. Avid says do not use firewire with win 7 so I'm checking out new data drives using USB 2.0.
Any help greatly appreciated....Thanks
George
Old 04-05-2011, 06:58 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: usb 2 hard drive for pro tools 9 use
is this for a desktop or laptop?
Have you considered using e-sata, which is much faster than USB or firewire, or using another internal hard drive if you have the space.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 04-05-2011, 07:31 PM
Good point above. I also answered your duplicate post. Now, from the top of this and every DUC page
Please post your message once only to the correct forum
Old 04-06-2011, 05:45 PM
Thanks for the info, I am aware of e-sata, but I'm looking for portability between laptop and desktop, as well as external to the pc
Old 04-06-2011, 05:46 PM
Thanks for the info, I am aware of e-sata, but I'm looking for portability between laptop and desktop, as well as external to the pc. Point taken will only post in one forum
Old 04-06-2011, 07:38 PM
Benoni's Avatar
Well so you know, there are many External Hard drives with Dual or Tri interfaces (USB+E-SATA, or USB,Firewire, and E-SATA ports)
For external drives, its usually cheaper to "build" your own. Just buy your favorite internal hard drive, buy an External Enclosure, and put the drive in the case.
These cases work good for me, and have E-SATA and USB2.0 connections
http://www.newegg.com/Product/Produc...-042-_-Product
http://www.newegg.com/Product/Produc...-043-_-Product
Also the Western Digital MyBook Home external drive works ok with Pro Tools and has USB, Firewire, and E-Sata hook ups.
If you buy an empty case, then Western Digital Caviar Black hard drives with 32MB or 64MB cache would be a good choice for a hard drive to put in the case.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Hard Drive for Pro Tools 11 Becharax Pro Tools 11 25 07-01-2013 07:32 AM
Pro Tools HD with WD 3TB Hard Drive stephenandthemockingbird Pro Tools TDM Systems (Mac) 3 02-04-2013 09:06 AM
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Pro Tools Needs it's Own Hard Drive? romeoplank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-01-2007 09:21 AM
Help with Pro Tools hard drive SteveGarman Pro Tools TDM Systems (Mac) 4 03-23-2004 02:52 AM
