Old 07-22-2024, 10:58 AM
sw rec sw rec is offline
Default 2024.6 on MAC VENTURA not keeping windows positions
Anybody else? Pro Tools 2024.6/Mac Ventura/Rosetta mode, closes the MIX window EVERY TIME you close the session, and when you re-open it, you have to restore the mix window manually. It's minor I know, but it used to store my window positions.
Used to have mix left/edit right. When you manually restore the MIX window it always puts it to the right OVER the edit window. What am I missing?
Old 07-22-2024, 05:02 PM
Tweakhead Tweakhead is offline
Default Re: 2024.6 on MAC VENTURA not keeping windows positions
Try this.
Position your windows how you like, but this time leave about a quarter inch space between the bottom of your Edit or Mix window and the bottom of your monitor screen.
Save a Window Config.
Save the session.
Close, Quit. Reboot. Relaunch.
Any difference ?
Old 07-22-2024, 06:51 PM
Nope, that didn't do it either. I even saved my preferred layout as a specific configuration (ALLAN DEFAULT) but recalling the setting still doesn't put the mix window on the left monitor where it's supposed to be. It only started doing this when I updated from 2023.12 to 2024.6. You have to re-activate the mix window, and drag it over to the left monitor. I remember when on Windoze you put the windows where you wanted them and did an ALT-F4, and it'd remember them every time. Will try that here in a minute. Thanks for the reply!
Pro Tools Ultimate 2024.3 Freeze on Boot Ventura 13.6.5- FIXED bluesatyr macOS 3 05-22-2024 02:56 PM
HD driver 2024.3 not working properly with Ventura 13.6.3? Frans29 Pro Tools 5 03-21-2024 11:00 AM
Edit and Mix Windows Positions Not Remembered after Saving and Relaunching Pro Tools Kam Lion Pro Tools 14 06-14-2023 12:41 PM
Error 997 Keeping Pro Tools From Installing (Windows 7) SoundGuyMusic Windows 6 10-24-2014 10:42 PM
Keeping Mix and Edit windows open Mike62858 Pro Tools M-Powered (Win) 4 12-21-2006 01:54 PM
