Old 07-19-2024, 12:36 AM
reneo reneo is offline
Default Marker / Memory location zero
There was a bug/feature in PT for ages. One could recall the highest number marker/memory location with zero. Zo instead of typing period-3200-period, you could just type period-0-period. I use this a lot while moving clips around or as vast recording starting point.
This bug/feature doesn't work anymore from 2024.6. IS there a way to bring back marker zero? ;-)
Old 07-19-2024, 01:42 AM
Default Re: Marker / Memory location zero
it does work fine in 24.6 (I think it was broken since 23.12) but the marker needs to be listed in the marker window. When you have a filter active which hides marker 32k the .0. shortcut won't work. Pretty annoying, yes.
PTHDnPCIe 2025.6 (OSX15.5), Eucon 25.6, 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 07-22-2024, 12:46 AM
Originally Posted by Frank Kruse View Post
Ah! That's it! Thanks!
Old 08-17-2024, 08:40 AM
BernOReilly BernOReilly is offline
I still cant' get .0. to work in 24.6
Frank can you explain this bit...maybe this is where I'm going wrong?
Old 08-17-2024, 11:11 AM
smurfyou smurfyou is offline
Originally Posted by BernOReilly View Post
It needs to be visible in the marker window so won't work if you have them filtered by the icons or a search that excludes # 32000.
~Will
using numeric keypad to jump from memory location to memory location eVERB Sound Pro Tools 5 06-11-2024 12:27 PM
Bug When Activating Marker Location Colors Hannibal Lecter Pro Tools 12 2 12-23-2015 03:07 PM
Problems with Memory Location/Marker Import thaumaturgist macOS 4 06-24-2013 06:09 PM
Question about location marker miketmbt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-24-2011 05:47 PM
Memory Location Marker Does NOT Update After Edit Cuts wdjudd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2007 05:12 PM
