Hi All,
Sort of a newbie question, I guess. I was just reading some reviews of microphones that have a 10dB pad feature. Is this just an attenuator? I'm not really clear as to why this would be a good feature to have. Couldn't you just turn down the input on your mic pre and achieve the same result? Thanks for any replies! |
Some mic outputs can be hot even without a preamp to boost them. It also allows the mic to handle more SPL like infront of a guitar cabinet or snare drum.
CYE,
As a matter of fact some mics have -10/-20 pad switches or insertable pads between the capsule and the amplifier body. This could be a lifesaver, as most pre-amps input will overload long before the "gain" knob can be activated.. capice ? happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
OMG, I always hated those damn screw on pads with my old AKG C-451EBs.
BTW Lemix, how have you been? |
A condenser microphone has either a Field Effect Transister (FET) or tube amp inside which basically operates as a preamp and impedance converter. On a loud signal source like drums, a pad on the microphone prevents that FET or tube from clipping and causing distortion before it ever reaches your console.
All condensor mics have a preamp in them, that's why they require phantom power.
Using a condensor mic with a pad is a great feature. No pad for vocals and almost always use the pad for drums. Most dynamic mics have no pad at all. And none is needed. A pad is very important for condensors due to thier high output.
SE Microphone Bundle Question | shultzee13 | Pro Tools SE and Essential (Mac) | 1 | 08-21-2013 05:48 PM |
Microphone Question | mike1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-18-2008 04:46 PM |
Microphone Question | Joe11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-16-2008 06:25 PM |
question about microphone | fender101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-17-2008 03:52 AM |
Microphone/PreAmp Question | vocalize | Tips & Tricks | 1 | 04-08-2004 01:08 AM |
