  #31
Old 05-10-2024, 07:50 AM
Redmann Redmann is offline
Default Re: Locking the trim tool!!!!!!!!!!
Thanks for the tip on the keyboard shortcut. You can somewhat achieve that by selecting the tool's mode you want and using the Option menu > "Edit/Tool Mode Keyboard Lock" feature. That said, what I (and I believe others) would like to see is a way to still cycle the modes but remove or lockout some modes they don't want to use commonly.
For example, I'm old school and like to use the command+2 and command+4 commands to cycle the Trim and Grabber tools (and sometimes their modes). I generally use the Standard Grabber mode and also the Object Grabber; I seldom use the Time and/or Separation Grabber modes. It would be ideal if I could program the Grabber to cycle b/w Standard and Object mode using command+4. I would like to omit the Time and Separation modes from cycling using command+4. If I want one of those modes, I'll use the mouse to select.
Currently, if you attempt to program the Keyboard Shortcuts for this and assign both Standard and Object Grabber to command+4 it detects a conflict and doesn't cycle.
  #32
Old 05-10-2024, 07:52 AM
See Conflict Screenshot
File Type: jpg Screen Shot 2024-05-10 at 7.51.05 AM.jpg (23.1 KB, 0 views)
TCE Trim Tool Ginridge macOS 2 09-28-2012 08:15 AM
8.0.3 - worth it for the tool locking alone! dopplah Post - Surround - Video 5 12-25-2009 04:27 PM
Tool Selection - locking in place TinyE1017 Pro Tools TDM Systems (Mac) 1 02-26-2009 08:57 PM
Problems with Grabber Tool & Trim Tool S133 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2008 10:19 PM
trim tool on 7.4.2 ? dendee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2008 09:40 PM
