Old 11-29-2022, 01:05 AM
ihate100bees ihate100bees is offline
Default Issue with Melodyne Studio 5 after updating from 4
PT 2022.10
Win 10 pro.
Recently updated from Melodyne Studio 4, to Studio 5. In PT prefs menue it says "Celemony ARA". But I see it studio 5 listed as "Melodyne" under "Other" in the plugin's menu... is this right?
Problem is that I STILL also see Melodyne 4 listed under "Instruments? If I try to load it, a message appears that says ..."AAE Error code 20038 was encountered"? I was told by Celemony tech support to Un-install 5 and re-download it, then re-launch. Did that and still seeing what I described. Anyone else having similar problems?
Thanks.
Old 11-29-2022, 09:57 PM
Default Re: Issue with Melodyne Studio 5 after updating from 4
Ok... FIXED the problem by trashing PT Preferences, than going into Windows App folder, and locating the hidden Melodyne Un-install aplication. Re-installed Melodyne Studio 5 and everything looks good... and no visual of the old Studio 4. Hope this helps someone else.
Why are MIDI notes 1-2 samples ahead? 2022.9/2022.10 gthm Pro Tools 9 06-30-2023 01:10 PM
Melodyne doesn't render properly after TCE Tool 2022.10 and 2022.9 Dizzi45Z Pro Tools 4 01-04-2023 02:31 PM
Super SLOW mp3 import bug is back in 2022.9 and 2022.10 akproductions1 Pro Tools 12 11-01-2022 08:48 PM
Will sessions created in 2022.9 open in 2022.7 michael c Pro Tools 1 10-21-2022 09:09 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
