Solo's do NOT work with groups!
here's the bug. I create a group and manually assign the "Follow Globals" and set the globals to "solo".
Sidenote: Why do I now have to manually assign "Follow Globals" and "solo" for my groups? Up until 7.4 solo's would always automatically work with groups! Anyway, after doing that, the solo's are grouped. When I assign that group to a VCA, however, I am now no longer able to group solo...I must use the VCA (which I don't want to do since the VCA will be hidden). The STRANGE part is that when I take that group off of the VCA, the solo's no longer are grouped, even though its still part of the attributes! HUGE BUG that needs to be fixed! |
Re: Solo's do NOT work with groups!
It is not a bug. When a VCA is assigned a group, soloing is disabled from the group and only available with VCA master. If you still want group solo and VCA control, make a second group with solo only for the same tracks.
Gil
Gil Gowing Principal Digimidi Technical Services |
I've been using this setup for a long long time, and have always been able to solo the group when the vca is active...also, why, when I disable the vca, does it still not allow group solo?
AND, why does it not default to group solo when I create a track...it used to always do that.
NOW, having the option to go and assign them things OFF of the operational options in a "group" would be cool. But upon making a group they should ALL be on and working by default making all the tracks in the "group" act as ONE. Then let us go in and "customize" them from that point if we so desire. JMO though -
ROULETTE RECORDS™ (415)334-8742 office (267)219-4490 fax www.rouletterecords.com [email protected] Any fool can complicate things; It takes a genius to simplify them __________________ |
AMEN!!!! And thank you...now I know that I'm not just going CrAzY!
It is ridiculous, VCAs or no, it should solo as a group. Bad "decision" making once again.
+1
+2
Please don't change this. This is half the reason for VCAs, to have a Master level and solo, while still being able to change level/solo/mute of the group members.
PT 8 Solo's & Groups | TommyT | Pro Tools TDM Systems (Mac) | 1 | 05-30-2010 02:34 PM |
SOLO's SHOULD FOLLOW GROUPS!!!! | Kourquie | Pro Tools TDM Systems (Mac) | 25 | 10-01-2009 09:49 AM |
solo groups won't work ? | Grammasta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-03-2009 09:24 AM |
Please Digi make the Edit groups work again! | crizdee | ICON & C|24 | 0 | 10-12-2006 01:52 AM |
Anyone getting BFD groups to work w/MBOX | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-24-2005 01:00 PM |
