Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 01-05-2011, 01:46 PM
dazzb1987 dazzb1987 is offline
Default No/weak signal
I have just bought M powered essential and i am having problems recording my bass. the box just doesn't seem to be receiving signal and when it does it is weak or delayed regardless of the levels. The mic/guitar switch is in the correct position and it isn't my pick ups or lead (well the lead is getting old but still runs through my amp). Is it a fault i am making or is the box poor receiving direct from a guitar? if so i have a head or practice amp i can run through but i don't have enough leads at the mo.
Thanks
Old 03-09-2011, 01:12 PM
paydoogs paydoogs is offline
Default Re: No/weak signal
Had the same problem with my guitar. Looks like it is due to the passive pick-ups having an impedance mismatch with the box.
A DI box was recommended, but I just put the guitar through a multi-effects pedal which gave it a bit amplification for recording.
Try connecting the amp output to your box or 'mic' up the amp.
Sorry, but you'll need another cable.
Weak Signal Problem StuckWithMCE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-22-2011 03:54 PM
MBOX 2 - Weak Input 2 Signal grhufnagl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2008 11:32 AM
weak signal..please share your ideas if possible tritonkorg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-18-2005 10:29 AM
Weak Signal Recording Electric Guitar lawley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-09-2003 05:26 PM
cant run digi out to outboard gear because signal is to weak apesauce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-28-2002 10:00 AM
