Pro Tools freezes when trying to open old sessions
Just upgraded to Snow Leopard and PT8.0.4cs2. PT wil launch by itself and I can access all plug-ins, etc., but when I try to open sessions that were created in PT8 with Leopard, Pro Tools freezes during the session's progress bar. I then have to force quit PT. Tried trashing the prefs and repairing permissions. Even went to the cs upgrade when this was originally happening in 8.0.4. Went to Snow Leopard while waiting for PT9 to be delivered, and now cannot work on old sessions. Please help.
js_nyc 15" Macbook Pro (Mid 2012) 2.3 GHz Intel Core i7 16G Memory PT 10.3.11/ 12.5.2 003 Rack OSX 10.8.5 ProToolsConsultant.com |
Re: Pro Tools freezes when trying to open old sessions
Check for outdated plug-ins. Old plugs are deadly.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I don't think the compatibility grid changed from 8.0.4 to 9.0 so the plugins shouldn't be the problem IMO.
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
Plus he hasn't indicated his OS version.
Park Seward is right. What plugs are you running on the old sessions and if you create new sessions when you say import the old, the old what? You can import the session and uncheck in the "track data to import" the plugin assignments and plugin setting and automation. That way you can illuminate the possibility of incompatible plugins. EDIT: I realize you mean't the old sessions, but again uncheck those items I mentioned to see if there is a plugin conflict.
Thanks, guys. It must be a plug-in issue and when I narrow it down, I will re-post.
Sorry, my signature was old- here is the new signature to show all system details.
I installed Avid plug-in updater version 8.0.3 (most current). Now, when trying to open instrument plug-ins in a new session (even click) will result in blank bars and lines where the presets usually are. When trying to load Hybrid it's colors are all messed up (as well as blank preset tabs, etc.). I took screen shots but am not sure I can attach them here. Digi/Avid please advise.
When you upgraded, did you actually upgrade from leopard or did you do a clean install of Snow Leopard. At this point, it sounds like your system is corrupt and instead of spending more time trying to troubleshoot to fix, I would start over with a complete fresh install of SN then Pro tools and make sure you do all the optimizations for your mac. It happens too often to all of us with our systems that we end up spending more time trying to fix something when clearly the best thing is to start over.
Pro Tools 10 Freezes when Reference Guide is Open | MikeX2 | Windows | 25 | 07-16-2013 01:46 PM |
Pro Tools Freezes When Opening Sessions | farrantch | Pro Tools M-Powered (Win) | 12 | 05-30-2013 04:40 PM |
protools freezes when i open ONE of my sessions help! | KevinAllen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-04-2010 07:35 AM |
Strike dpm Freezes, Cannot Open Pro Tools 8 | vlakanas | Virtual Instruments | 7 | 05-19-2009 11:47 PM |
Pro Tools freezes when opening sessions | justinbahrami | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-06-2004 06:03 PM |
