Old 04-02-2022, 01:19 PM
nelsonmay nelsonmay is offline
Default OSX downgrade to run PT 11?
I am doing some searching and can't get a solid answer? Sorry if I missed something, but can you guys help me out? I thought I would ask you guys straight up.
I have a 2020 Mac min M1 that is maxed out. Since I am not billing in audio any longer I haven't upgraded since PT 11. I have been seeing some threads where PT is running on an M1, but they are hard to verify.
I want to try something. Since I have a 1TB drive, can I partition and downgrade to a previous osx and can it run PT 11? I think I can only downgrade to Catalina?
I just like having PT around in case I have to go into a private project.
Is it worth trying or should I not waste my time.
Old 04-02-2022, 01:48 PM
protoolsuserman protoolsuserman is offline
Default Re: OSX downgrade to run PT 11?
You won't be able to run an older mac osx on the M1 chips.
PT 11 requires Yosemite
So pt11 definitely won't work with the M1 macs unfortunately.
Old 04-02-2022, 04:24 PM
Here is the Protools Compatibility Chart:
https://avid.secure.force.com/pkb/ar...tibility-Chart
And for your information the M1 Mac Mini can only run with Big Sur or newer versions of macOS. The rule of thumb is that Apple Macs can only run on the version of macOS that it was originally released with or newer (until the the OS is too many version ahead that the old hardware can not run it).
Obsidian Dragon
Mac Studio M1Max - 64GB
Help with downgrade to OS X 10.8 for PT 11.3.1 algerij macOS 5 09-25-2016 12:52 PM
I need to downgrade from 10.11.6 to 10.11.3 jamesleonard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-19-2016 11:46 PM
Downgrade ? Lahmuh Licensing & Accounts 3 02-16-2016 10:09 AM
Downgrade 8.0.3 to 8.0.1? JBCSL Pro Tools TDM Systems (Mac) 0 01-05-2011 06:25 PM
How to downgrade to 10.4.8????pls pls pls help! Kstyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-20-2007 11:11 AM
