Old 10-20-2010, 03:17 PM
chavernac chavernac is offline
Default Record in 88.2khz > edit&mix on Mbox 44.1khz > back to 88.2khz
Hi everyone.
A friend of mine recorded a song in PT HD 8. The files are 88.2 Khz 24bits.
I only have PT LE 8. I saved a copy in 44.1khz and started to work on it.
Please tell me that I can finish my work (editing, mixing, plugins etc...) and that once the work is done, I can come back to the original 88.2 khz files ....
As anyone done that already?
There are probably several options here...
Thanks a bunch!!!!
Old 10-21-2010, 05:16 AM
mindnoise mindnoise is offline
Default Re: Record in 88.2khz > edit&mix on Mbox 44.1khz > back to 88.2khz
To my understanding: no.
you downsampled to 44kHz. so you need to upsample you session again, which MIGHT be a big difference compared to your original 88kHz files.
last: PT11.3.1
Old 10-21-2010, 05:48 AM
priorytools priorytools is offline
If you're just editing regions, you could export region definitions or export region groups ? Page 305 of manual.
This may well work. .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Recorded at 88.2khz Raoul23 Pro Tools 10 1 10-15-2012 12:11 PM
Applying a 44.1khz session to 88.2khz Audio Files Andrew. D Pro Tools 9 3 02-08-2012 04:59 PM
Problems with 88.2khz sessions in pt9 boabyd23 Pro Tools 9 2 03-21-2011 01:34 PM
Some opinion please. Using 24/44.1khz equipment when mixing in 24/88.2khz Khaarmeyer Pro Tools TDM Systems (Mac) 1 03-05-2009 10:37 AM
annoying 2kHz tone when using Mbox Mini rimlord 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-03-2007 11:03 AM
