"punching in" question
HI,
Is there a way to set an automated punch in? say i wanted it to punch in at bar 4 but be out of record at bar 5? If so how do i set this up? Thanks, Luke K
Intel Quad Core 2.83 ghz 4 Gig Ram 2x 1Tb 7200rpm seagate Hard Drives Pro tools 8.0.1 003 Rack Mackie Mr5 monitors Windows Vista Home Premium Sp1 |
Re: "punching in" question
Simply select that range of time, turn on pre-roll and post-roll and set them for the desired amount. Use Quick Punch so you have some crossfade time if you need it.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
David said it; but in laymen terms, & that isn't directed @ u Luke, jus highlight where & how much u want to record & follow David's steps... Just making sure u fully understand what to do...
Just a note - because this happened to me a few days ago.
The place where you set up your pre-roll time is in the transport window. Go to the "window" menu and make sure you can see the "transport" window. Furthermore, you have to see the bottom half of it. Click the arrow in the upper right corner and select "expanded transport." It also helps to have your session set up for bars/beat instead of minutes/secs. Hopefully, you set up your original session to some kind of a click so you have a working grid. That makes it eaasier to set up your pre-roll for a simple "2 bars" for example. If not, you can still use seconds for pre-roll. The, with the selector tool highlight the exact area you want to punch in - hit rec+play. Make sure Pre-roll button on transport window is LIT UP or else it won't work. I just had a session where I had to re-light it every time I wanted to punch in - not sure why.
- but the second mouse gets the cheese |
Actually u can just set ur pre/post roll time by holding the start key & clicking where u want the pre/post rol to start/stop...
What I do is not use preroll or count-off, but select a bar infront of where I want to punch in along with the area where I will be recording and maybe even past it by a bar. Then put record in loop mode and record as many takes as you want. Each time it comes around to the start you get that 1 bar count into the punch. For rehersal put play in loop also.
You can also set PT8 to loop record right into playlists, but I prefer to let the takes pile up in the region bin so I can get rid of the bad ones real fast. Don't forget to set "Record at Selection" in preferences. |
Ok I have the area selected where I want to record. It records where I tell it to but I need a lead in. Tried fiddling with the pre roll in the transport window but didnt change anything. I just need to hear about 5 sec of the end of the midi piano track before it punches in.
Pre/post roll will not work if you have enabled the Dynamic Transport. Make sure you turn it off. Otherwise just place the cursor at the lead in time you want to start and it will begin recording when it reaches your loop start point.
And if you set this in the transport window, don't forget to hit enter.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Simple Question about merging "Grid" & Shuffle" Features. | Coloud | macOS | 4 | 10-11-2012 05:05 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
A "Yes" guitar tone question, from "Fragile" | Sabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 01-06-2003 07:51 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
