10.5.8 Qualified - Is this silly?
"Pro Tools 8.0 software requires Mac OS X 10.5.5, 10.5.6, 10.5.7, or 10.5.8, and is not compatible with earlier versions of Leopard. If you have an earlier version of Leopard, you will need to update your Mac OS using one of the following Combo Updates before installing Pro Tools 8.0:"
So, what, are we supposed to remove PT8 if you're already running .5/.6/.7 and then go through all the install process again?
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
Re: 10.5.8 Qualified - Is this silly?
I read that as 10.5.4 or lower will require the OS update, then PT installation
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Thanks flommer... Sorry folks
I am a new Mac user so I just do not know everything about Mac yet. But I will:-}
I am running M-P_PT8 on a Mac Book Pro. I did the 10.5.8 update using the installer in the OS. Then I read later about the Combo Updates. Should I install the 10.5.8 Combo updates? Or leave it alone? What should I do? Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Are you having problems?
Make sure you Repair Disk Permissions afterwards. After any install actually
MacPro 8 Core,2.4, 14 Gig Ram. OSX 10.8.2 |
Thanks.
I feel silly asking but... | paulrgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-21-2010 11:34 PM |
Silly me | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-22-2006 06:06 AM |
silly bug in 6.4 | Niljam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-14-2004 07:31 AM |
It's really a silly war... | Charles D. Ballard | Pro Tools TDM Systems (Mac) | 34 | 09-05-2002 08:24 AM |
Silly, silly voice allocation | johnwhynot | Pro Tools TDM Systems (Mac) | 3 | 03-18-2000 06:38 PM |
