Driver install issues with LE7 and MBOX 2 PRO on
Hello,
I'm a new user to protools (but started doing music on a computer on a mac 15 years ago ...) and I got myself the mbox2 pro factory for xmas, on a big dell dual core with 2 gigs. I have been able to use protools 2 hours since i bought it, and I have a an issue where i'm told that the only solution is to reinstall all my PC ... which i would like to avoid. Here is the issue: I cannot have a stable installation of the mbox2pro. after numerous installs, deinstalls, in 7 and 7.3, it looks like i cannot install the drivers of the mbox2pro. I have a "!" on the mbox symbol in the peripherals management window, and it says "windows cannot start the device, error 10". Of course, the mbox works fine, as I've been able to install it on my wife's machine. It did work at some point, so I suspect that there is some file staying hidden somewhere that the installer does not like, but the standard "remove programs" does not fix it; I've been advised my the european tech support to go in the registry to remove protools entries, whiwh i did, but there are also tons of mbox2 entries there ... and I'm scared to make too many changes in the registry as I understand it may f***k my whole configuration. So if anyone knows how to do surgery on the digidesign drivers, i will welcome the information, il will save my week end reinstalling windows ! I'm surprised that it is so difficult to install products from a well established brand like digidesign . Thank you, whoever can help me. Free bottle of champagne offered if you come to Paris Philippe PS====my config < Système > Nom de l'Hôte: HO_075 Utilisateur: Philippe Domaine: HYPEROFFICE < Processeur > Modèle: Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz Vitesse: 2.00GHz Taux de Performance: PR6790 (estimé) Noyaux par Processeur: 2 Unité(s) Threads par Noyau: 1 Unité(s) Type: Mobile, Double Coeur Cache de Données Interne: 2x 32kB Synchrone, Ecriture Directe, jeu à 8 voies, 64 octets de taille de ligne Cache sur Carte L2: 4MB ECC Synchrone, ATC, jeu à 16 voies, 64 octets de taille de ligne, 2 partages de threads < Carte mère > Bus: ISA X-Bus PCI PCIe USB FireWire/1394 i2c/ SMBus Support MP: Non APIC MP: Non BIOS Système: AT/AT COMPATIBLE DELL - 27d60c12 Carte mère: Dell Inc. Mémoire Totale: 2GB SDRAM-DDR2 < Chipset 1 > Modèle: Dell Computer Corp 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller Vitesse du Bus Principal: 4x 166MHz (664MHz taux de transfert) Mémoire Totale: 2GB SDRAM-DDR2 Mémoire Echangée: 8MB Vitesse du Bus Mémoire: 4x 132MHz (528MHz taux de transfert) < Dispositifs de Stockage Physiques > Disque Dur: WDC WD1200BEVS-75LAT0 (110GB) CD-ROM/DVD: TSSTcorp DVD+-RW TS-L632D (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) < Dispositifs de Stockage Logiques > Disque Dur (C:): 81GB (25GB, 31% Espace Libre) (NTFS) Sauvegarder (D:): 27GB (21GB, 81% Espace Libre) (NTFS) GitCD_285 (E:): 514MB (CDFS) < Périphériques > Port(s) Série/Parallèle: 1 COM / 0 LPT Contrôleur USB/Hub: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 Contrôleur USB/Hub: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 Contrôleur USB/Hub: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA Contrôleur USB/Hub: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB Contrôleur USB/Hub: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC Contrôleur USB/Hub: Concentrateur USB racine Contrôleur USB/Hub: Concentrateur USB racine Contrôleur USB/Hub: Concentrateur USB racine Contrôleur USB/Hub: Concentrateur USB racine Contrôleur USB/Hub: Concentrateur USB racine Contrôleur USB/Hub: Concentrateur USB générique Contrôleur/Hub FireWire/1394 : Contrôleurs hôte IEEE 1394 compatible OHCI Clavier: Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2 Souris: Synaptics PS/2 Port Pointing Device < Dispositif(s) de Communication > Dispositif: Conexant HDA D110 MDC V.92 Modem < Système(s) d'Exploitation > Système Windows: Microsoft Windows XP/2002 Professionnel 5.01.2600 (Service Pack 2) |
Re: Driver install issues with LE7 and MBOX 2 PRO
Well, I have some bad news for you. Well, Digidesign does, really, I'm just the messenger (and please don't shoot the messenger ).
Please read the Mbox2 Pro compatibility page carefully. Your bad news is located there. Specifically: Quote:
So, it's not a file, its hardware related. Your only solution is to use it on a different computer, I'm afraid.
Hi SPKguitar,
Thanks for your answer ... even if it's not really what I'd like to hear ! still what puzzles me is that the hardware did work for a while and then went to lalaland. And then I think : if it did work, it should work again ! I think that i'l going to reinstall my PC and if it still does not work, I'll buy a little mac, this was not planned in the budget !!! Which configuration do you use ? Thanks and have a great day Philippe |
Install Driver for Mbox Pro 2 and PT9...help! | Kelly Vaughn | Windows | 1 | 02-19-2011 06:37 PM |
Mbox 2 driver re-install randomly whenever MBox plugged in | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2008 08:22 AM |
Can't install Mbox driver | sminnis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-30-2007 08:56 AM |
Driver Install issues | Red Fox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2001 12:59 AM |
