Old 08-06-2006, 09:09 PM
mrufino1 mrufino1 is offline
Default Laptop power supply issue?
have a strange question I think. I use an emachines 6805 with protools m-powered, firewire 1814, behringer ada8000, mackie 1604vlz in a 10/10 mixer rack to do mobile recording. Last Sunday I had a session at a band's rehearsal space and my computer shut down 3 times and twice reverted to 600x800 with an error message saying the graphics driver failed. I plug my computer and firewire drive into the power strip in the rack, computer ground is lifted because otherwise there is noise, then the rack is plugge dinto a UPS with a voltage leveler circuit. I just finished my pm-1000 preamps and put them in the rack as well, and I had messed something up while putting htem together so I took them to an electronics tech who got it working correctly. However, this was the first time it was mounted in the rack. Today at church I was recording as well, and during rehearsal it again shut down. I thought maybe it was the pm-1000, so I stopped using it, unplugged it, and no more shutdowns during the church service and mixing. SO, what might be causing this? Is the pm-1000 causing a voltage drop, therefore makign the laptop get screwy? I fugure the power supply is not very robust or tolerant. If this is the case, do you know of any higher quality laptop power supplies, or is there a way to adapt a desktop power supply to use with a laptop (or is there alreayd one commercially available?)? One of the musicians I work with was an electrician and is now a computer programmer, and he said this may be the case. He also suggested we build a rackmount computer using a server he has that is unused, which may be an option, but financially I'd love to not go all out on a new machine unless I really have to (in which case the laptop would sold to finiance the new machine). Anyway, if anyone has any ideas that would be great. Thanks-Mark
Noise through monitors when laptop power supply is plugged in christopher.tempest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-09-2010 10:35 AM
Project Mix I/O power supply issue! anyone else? RuffJazzRecords Pro Tools M-Powered (Win) 2 09-27-2007 04:54 PM
G5 power supply issue emilano Pro Tools TDM Systems (Mac) 4 12-02-2005 12:10 PM
002 RACK POWER SUPPLY ISSUE Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2005 06:51 AM
Control 24 Power Supply Issue digi2000 ICON & C|24 1 06-05-2004 07:11 PM
