Old 08-23-2011, 06:25 PM
TehRedRumRunner TehRedRumRunner is offline
Default Setting up HUI in ptle 8
So I have the slights clue on how to set up my zoom hd16 with my protools. Any advice would help, the only way I've been able to even get it close to working is via midi...
Old 08-23-2011, 06:44 PM
shanabit shanabit is offline
Default Re: Setting up HUI in ptle 8
1.Set your ZOOM to the HUI control, see the manual for that
2. Connect the MIDI OUT of the Zoom to the MIDI IN on your protools interface or midi box your using
3. Connect the MIDI OUT of the Protools interface or midi box to the MIDI IN on the ZOOM.
4. Go to the peripherals window in Protools and select HUI as the control surface and select the MIDI OUT port your using and the MIDI IN port your using.
THats all I can remember since I dont have tools anymore nor am I using HUI now
MacPro 8 Core,2.4, 14 Gig Ram.
OSX 10.8.2
Old 08-23-2011, 08:16 PM
Ok, now that out of the way it's giving me a message saying "' protools is unable to communicate with the hui. Powercycle hui and check connections(good). Note, if hui is not in use, update the peripheral dialog to prevent further warnings" ...
Old 08-23-2011, 08:30 PM
Benoni's Avatar
Benoni Benoni is offline
Windows or Mac?
If the Zoom has MIDI over USB I personally would just use the USB cable instead of MIDI cables, but I am not familiar with the Zoom.
Make sure the Zoom is powered on before you start your PC.
If you are on Windows Vista/7 make sure you Right Click the Pro Tools Icon and choose Run As Admin instead of just double clicking to launch.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 08-23-2011, 09:44 PM
If you have the cables hooked up to and from the Zoom and youve selected the HUI in the peripherals AND selected the MIDI port your using then the issue is now at the ZOOM, make SURE you read the Zoom manual and figure out how to put it into HUI mode. If not, you will get that error. If the midi connections are not bi-directional or the ZOOM isnt set to HUI mode youll get that issue.
OSX 10.8.2
Old 08-23-2011, 09:53 PM
NOTE: If the Zoom DOES NOT support HUI control surface mode your screwed, period.
http://s3.amazonaws.com/samsontech/r...8_HD16_daw.pdf
http://s3.amazonaws.com/samsontech/r...ser_manual.pdf
All Im seeing is Cubase control
OSX 10.8.2
PTLE I/O Setting Difficulties akakpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-18-2007 12:00 PM
Setting up PTLE Mcgrathx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-10-2004 06:40 PM
Setting up Yamaha 01V as a Controller in PTLE slopoke MIDI 4 10-07-2003 02:40 PM
HELP WITH SETTING UP MIDI KEYBOARD W/ PTLE 6? KevinWild 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-19-2003 05:12 PM
Setting up G4 for digi001 PTLE new kid in town 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-21-2002 12:26 AM
