setting default inputs and outputs
I've looked in the preferences and can't find this: how do set the default i/o to 'whatever' (eg. when you create a new track it will come up with outputs set to analog 1/2)
Thanks
002R; G4 Powerbook 1.5Ghz 1GB RAM OSX 10.3.4 Firewire 800 external drive 001; G4 533 1GB RAM OSX 10.2.8 |
Re: setting default inputs and outputs
hi icouri
You go to i/o set-up on the top bar - i think under Hardware menu - and you have a grid onto which you can define how channels on the 001/002 correspond to the tracks in pt. You wouldnt change the 1-2 w/ever, but you 'd change the in/outs corresponding to it. I think. |
I dont think it is possible.
The way I see it is that a new track will default to input: the lowest analogue input number not in use, and output: analogue 1/2. A workaround would be to create a session template with empty tracks set to the ins/outs you want, and then to duplicate those tracks when you need to.
Mac mini M2 Pro 32/512. MacOS 13.6.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1. |
You make a new path in the i/o set-up in the Set ups menu. It stays like that unless you re-default it. Check for yourself
You just re-assign different i/o on the digi001. I.e. 1-2 can stay as 1-2 in PT , BUT they are coresponding to whatever you want on the hardware i/o. |
I just checked Attanasi , you’re right.
You actually just have to shift the order from top to bottom of the I/O setup list. Whatever is at the top is first.
Cheers Ben,
If you have the time have a look at my Dodging Bounce To Disk thread, i was trying to do the same thing with inserts but it doesnt work in my case. Could do with an opinion. |
Can I change Audiosuite's default outputs? | infiniteloop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-25-2009 11:18 AM |
Questions about default settings for outputs and bouncing... | WATYF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-16-2008 08:20 AM |
Default input and outputs when upgrading from 001 | dizzyfingers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-24-2005 06:14 PM |
Can't Set Default Outputs...After All | tomhartman | Pro Tools TDM Systems (Mac) | 1 | 05-10-2002 01:14 AM |
Selecting default inputs and outputs? | Sound Guy Andy | Pro Tools TDM Systems (Mac) | 1 | 12-04-2001 08:08 AM |
