Cant open session from PTHD8
My PT9 cant open a session that was saved on a PTHD8
It get stuck on restoring some tracks. My PTHD8 is a HD2 at the moment in XP, still my main work machine My PT9 is a test machine ( as it is the first time in 10year I deal with a new OS ) running PT9 with an asio driver card. So ..I cant open any of my work sessions on PT9..they all get stuck on restoring some specific tracks. These track is either mono or stereo tracks, only having EQ37 as a pluggin I can see in the windows processes that PT9s use of RAM stop changing which means I guess PT9 crashes when trying to import these tracks Can anyone help me Regards Christian |
Re: Cant open session from PTHD8
Hold down the Shift Key while Opening (Loading) the Session, this will disable all of the Plug-Ins and the Session should Open.
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Back to this problem...
Hitting Shift while opening the session , disables all pluggins and yes opens the session. But when trying to opening the pluggs, by either activate them or move them to next slot, crashes PT9 I am speculating..what is happening here, is that PT is trying to op open the pluggs as RTAS, and after trying this manouver several times, i realize it seems like it is the Waves 8 pluggs that crashes PT. I wounder. could this be a Waves problem, or that PT9 is not compatible with Waves 8... While looking at the waves compatible plan I wonder if I have interpreted this sheet wrong, that as I have installed my PT9HD with a ASIO card, PT 9 is a "LE" system and I should have installed Waves7 instead... Could I be right with my speculations, or is Waves8 compatbile with my PT ? or should I do a Sandra report here. I must say that all news/changes with PT9 have been quite confusing for me... Christian |
Waves 8 should work fine with PT9. Could it be some other plugin?
No, its a plain 5.1 post session.
Basicly Eq3´s and a few renesance verbs on some busses Dialogue bus is the only one that have a mixture of digi and Waves. I dont use lots of pluggs,I am quite old fashionsed in my style. I will go through the optimize suggestions one more time... Christian |
Did optimize suggestions one more time, no difference.
But, I have now come down to the fact that it is NOT any problem activating the Digi pluggs..it IS the Waves pluggs that crashes PT will enabling them. So..what should I do..Sandra report...or go back to Waves 7 and try that one.. |
Christian, I had the same problem with a session with TDM-instances only (originally a 8.0.3 Mac session) when opening in 9.0.1. I'm on PC, but your PT9 was on Mac? Anyway, I was aware that these session may be too large to handle by my HD2 system when coming from a HD3. Trouble was the waves plugs (from the gold bundle) - not other plugs. The loading freezed on the track BEFORE the first waves-instanciated track. So opening the session without waveshell (now version 8 rev3) - deactivated the tracks containing waves plugs (keeping them as TDM), convert almost every other plug to RTAS for gaining TDM-power - save session, then open again with waveshell in the plugin folder. Then open the System Usage window to monitor the load on the different chips - then activate those tracks with wavesplugs again. Sure I could convert the wavesplugs to RTAS when inactive also, but this was test-and-try, and it worked.
pthd9-pt11 imac 14,1 / imac 7,1 / macbook air 5,2 / self-built hackintosh with gigabyte z97x board + quad i7-4690 |
Halstein, Hello from Sweden to dear Norway.
No, I am fully on PC My session came from HD and trying to open it on a PT9 with ASIO driver card..which means my PT licence will become LE in that machine. Its a test machine because I am not happy to leave XP after 10 fantastic stabile XP years. Your procedure seems very complex...could I phone you next week to ask you some questions about how you have installed your waves pluggs. After some email with Waves support I realize that all my waves optimisations for "european machines" differs from what I have done before and I am very confused. I think I must call Waves next week, because I realize that I cant even open some of the waves pluggs in a plain new session..it just crashes PT9. Its very frustrating, I am almost down to 20 hours of mess with PT9 and Waves8..crash, crash, crash what ever I try. Christian |
Hi again Christian.
I think you're in the ballpark concerning that "european" case!! When I contacted Waves, I got a quick response to try the following (I was suprised that THIS could matter - but nothing surprises anymore ): Quote from mail: Hi; Please try taking these steps to resolve the issue Go to: Start menu>Control Panel>Region and Language>and click on the Formats tab. Make sure that the first language in the pull down menu is set to English (US). Click on Additional Settings and make sure that you have the following settings: Decimal symbol: . (dot) Digit grouping symbol: , (comma) List separator: , (comma) Negative number format: -1.1 Please let me know how it works out. Thanks @@@@@@@@ Check it out, and good luck. Please contact me off list at [email protected]
song will not open, could not complete the open session commandbecause...while transl | SNAPPER | Pro Tools 9 | 6 | 02-11-2017 12:32 PM |
Pro Tools 9 crashes every time I open a new session or import session data | Ryan Butler | macOS | 14 | 03-23-2014 08:53 AM |
Pro Tools 8 crashing when I try to open a session or start a new session | AbstractHabitat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-25-2012 05:58 AM |
Tracks bin open every time I open a session | albee1952 | Windows | 5 | 10-04-2011 09:15 PM |
Unable to Open New Session, Open Session..... | ThisBeatsWorking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-16-2003 12:17 AM |
