Old 11-06-2010, 06:33 PM
DUCHUNTER DUCHUNTER is offline
Default Will PTHD8 Still Work with the 9 Auth?!?!
I asked my Sweetwater guy and was told that I would NOT have to surrender my PTHD 8 asset when upgrading to PTHD 9.
When I did the upgrade and went to download my new asset it states very clearly that my PTHD 8 asset will be surrendered in order to use the PTHD 9 asset.
This means I can't install the upgrade I just bought, as I have to keep PTHD 8 running on my system for a couple projects for the sake of stability. I was planning on installing 9 on a clone of my hard drive so I could run which ever I wanted.
Who's tried it or has the answer? Right now my V9 asset is still sitting in my account.
Thanks!
Old 11-06-2010, 06:51 PM
carlone carlone is offline
Default Re: Will PTHD8 Still Work with the 9 Auth?!?!
If you're installing onto the SAME ILOK as the 8 auth then I guess it will blow the 8 auth away. The question would be what if you installed onto a different ILOK?
Haven't tried that but it should work.
Waves does the same thing.
Old 11-06-2010, 07:15 PM
Previous DTS response: http://duc.avid.com/showthread.php?p=1690680
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
[IMG] code is Off
PT 7.4 Auth code doesnt work?? Amnesiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-30-2011 02:02 PM
loaded pro tools 6.4cs9 on laptop & auth code won't work mmclane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-06-2008 09:47 AM
Smack TDM auth. doesn't work for RTAS innesireinar Pro Tools TDM Systems (Mac) 5 04-29-2007 08:10 AM
SansAmp ILok's auth does not work...Digi please !! Aquarius Pro Tools TDM Systems (Mac) 5 05-27-2004 07:41 PM
6.2.2 Glitch: MP3 option auth code doesn't work Voxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-19-2004 05:41 PM
