Protools with USD stops reading after a while
Hi anyone else with the same problem?
After sometime protools won't react on the incomming TC. The USD is stil showing the correct TC and I can see it in PT, only the machinecontrol window won't update and PT won't react. As soon as I switch back and forth the TC type (VITC/LTC)in the session set-up window it will function again. I have this problem for a couple of years now and hoped it would be gone after updating from PT4 to PT5 and PT5.1 but it's still there. I'm using the latest version of the USD software. Thx for any help. |
Re: Protools with USD stops reading after a while
If you haven't already, try connecting your
USD to the Digi Serial Port on the Mix Core card as opposed to the serial port on the Mac. I had the same problem and that seemed to help. Also make sure your USD firmware is up to date.
When you once describe a venture as a holy war, you surrender all capacity to judge honest alternatives. -James A. Michener |
Oops, sorry, one other thing. Make sure
AppleTalk is turned off.
Thx I'll try the digiport. I thought the digiport was not recomanded for the USD.
BTW Appletalk is off. |
Protools not reading the amount of ram | ethics585 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-17-2007 06:16 PM |
File not open (-38) while reading "ProTools.vdb" | d_h | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-28-2007 07:14 PM |
Protools crashing when reading overviews - only 1 session | Mcpram | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-22-2007 10:27 AM |
Protools not reading signal through preamp | unseen33 | Pro Tools TDM Systems (Mac) | 5 | 02-16-2007 10:20 AM |
Reading ADAT into ProTools LE (002 Factory) | jdandrea | Tips & Tricks | 19 | 04-08-2006 06:30 AM |
