Old 05-27-2006, 10:16 AM
tdellaringa tdellaringa is offline
Default Function keys don\'t work? Conflict with Max OS?
When I am in PT, the function keys do not work as the shortcuts - they seem to function as MacOS shortcuts only. For example F6-F8 are supposed to be the selection tools, but they only work as setting the volume on the laptop and so forth...
Is this because I have a laptop? Can this be fixed?
Old 05-27-2006, 10:28 AM
Slim Shady Slim Shady is offline
Default Re: Function keys don\'t work? Conflict with Max OS?
On a laptop you would normally use the 'fn' key to access the regular functions for the F-keys, you're correct in assuming that becuase it's a laptop those keys default to the Mac OS functions that would normally have their own keys on a full-size keyboard.
Go to your keyboard & mouse settings in system preferences, there's a way to 'switch' the F-keys so that they operate normally for PT etc, and you have to use the 'fn' key to change volume, brightness etc.
Old 05-27-2006, 10:34 AM
Thanks, that worked!
Pressed some keys now shortcut keys wont work (T,R to zoom etc) Falcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-11-2016 11:49 AM
Can't turn off Mac Function keys/turn on PTLE Shortcut keys b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-25-2009 10:15 PM
Leopard: Function Keys don't work and PT won't "quit" djh108 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-03-2008 01:49 PM
Can't get F9-F11 Function keys to work in PT. Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2007 06:32 AM
function keys don't work as quick keys miked45 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2003 11:32 AM
