Old 08-10-2002, 06:50 AM
LEVON LEVON is offline
Default Re: linking two tracks together simply for stereo.how?
HEY BASTIAAN i appriciate your help realy.
i need to ask you something,i was told you can use anyother multitrack with the digi interface and souncard.if that so,can you tell me how to do that?i looked at my beloved samplitude v6 but its not showing the digi soundcard.
so,if you know how ,it would be appriciated.thanks again.
Old 08-10-2002, 06:57 AM
Bastiaan Bastiaan is offline
If you want to use your digi001 as an in- or output for other applications, the only thing you can do is install the wavedriver http://www.digidesign.com/download/wavdrv.html
this will let you use channels 1 & 2 of the digi001.
Another thing to come is direct-connect. We (pc-users) have it since version 5.3.1, but as of yet there are no applications that can use it. I think this will change, so you can have your softsynths and all running through d/c.
The other way people are doing it, is simply use another soundcard in your system with digital outputs. Connect those to the inputs of the digi001, fire up both programs, and you are set to go. All you nnow have to figure out is how to sync them together.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 08-10-2002, 07:06 AM
i am a pc user and i have the 5.3.1 version just bought it a week ago,it came with the new xp cd with the 5.3.1 drivers.
do i have to download the wave drivers since i have the version 5.3.1?
Old 08-10-2002, 07:11 AM
The wave-driver is probably on your cd. You need to have ptle installed before you attempt to install the wave-driver, but since you obviously are using ptle, that shouldnt be a problem [img]images/icons/grin.gif[/img]
What's that?
Bastiaan
Old 08-10-2002, 07:15 AM
In case it isnt on your cd, try this: http://download.digidesign.com/suppo...Driver_531.exe
What's that?
Bastiaan
  #16
Old 08-10-2002, 07:35 AM
i downloaded the wavedrver unzipped it but its not working.
i have samplitude i should see the digi soundcard in the systems but it is not showing anyway,sorry for the long hassle.i appriciated your help BASTIAAN.I have an maudio delta 1010 and its showing in samplitude but not digi.
  #17
Old 08-10-2002, 08:27 AM
ptrbas ptrbas is offline
About that linking and grouping issue.You can move the faders of a group independently with the right mouse button and as a group with the left button.
Pieter
  #18
Old 08-12-2002, 09:34 AM
metaltim metaltim is offline
Originally posted by Bastiaan:
the method i described will keep all the different regions intact, and you will not have to let the song play to do the bounce. Also my method will not take up extra space on your harddisk. The problem with my method is that you need to be able to create that stereo-track. If you are out of tracks, then you cant do it (easily...)
You would need to create another session, import the 2 tracks, create the stereo-track, drag the regions in that track, save the session, open your old session, delete the 2 mono-tracks, and do a import track from that other session....
<font size="2" face="Verdana, Arial">also, if you record using the time signiture within pro tools, all you have to do is move the two mono files on empty space to some other arbitrary track. Delete those two tracks, make a stereo track then get the two mono's on the stereo.
Like I said, if you have it all in time with the grid, you will very easily get it back in time.
Otherwise, don't move them horizontally
  #19
Old 08-12-2002, 09:38 AM
Stone Knife Stone Knife is offline
LEVON-
Please see the "Installing WaveDriver" section of the WaveDriver 5.3.1 Read Me:
http://www.digidesign.com/support/re...er_Read_Me.pdf
  #20
Old 08-13-2002, 03:49 AM
<font size="2" face="Verdana, Arial">If you by accident move some regions that shouldnt be moved, and where recorded on that spot, uou could use the spot-mode to put them back where they where in time (horizontal). Just set the mode to spot (top left corner of the edit-window), select the grabber-tool, and select the region. A window will pop-up, and in the lower part of that window is a section that says something like "original time-stamp". click on the butoon next to it, and hit enter. That's it.
What's that?
Bastiaan
SC48 pops when linking or un linking stereo channels lorenaguey VENUE Live Sound Systems 7 07-16-2013 08:11 AM
Stereo panner linking mattyharm Pro Tools 9 2 01-25-2012 05:41 AM
Stereo linking mono plugins? Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2008 07:45 AM
Pan Linking of Stereo Tracks SBP ICON & C|24 0 02-07-2008 11:53 AM
LINKING TRACKS FOR STEREO LEVON Pro Tools TDM Systems (Win) 6 08-31-2002 09:01 AM
