Old 07-23-2009, 11:33 PM
ppm ppm is offline
Default Peak Over Metering never light in 24bits record
When I record with the Fast Track Ultra 8r, the red clip light of input track on Protools8 never flash, even if the peak leds of FTU8r flash and I hear the overload. In fact the metering display is full range but never clip with the 0.0dbfs.
Furthermore, this problem occur only when I record in 24 bits deph on protools session, and if I record with 16 bits, the peak light flash normally.
Besides, with an other interface, the Maudio - Audiophile USB- , it's ok in 24 bits.
Can anyone else verify this and suggest an explain ?
Thank's a lot for your help.
7.3.1cs3 Incorrect Peak Over Metering Matt_G Pro Tools TDM Systems (Mac) 1 06-29-2007 04:11 PM
Interesting metering software (with peak logging) postprosound Post - Surround - Video 11 03-20-2007 02:36 AM
Mbox Peak / Peak Light Issue soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-29-2004 08:01 PM
Metering Average/Peak Levels chateau Tips & Tricks 5 07-01-2003 12:35 AM
Can someone explain the Difference between Peak and RMS metering TriAxis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-27-2003 06:28 AM
