I am trying to run pro tools le 7.3 on a Dell Latitude D830 and i get errors in device manager for the digi 003 rack. At first i was getting a code 31 error, then i disabled some drivers that i didn't need for pro tools to run and now i am getting a code 19 error message in device manager and it says "The configuration information is incomplete or damaged (in the registry)". The computer specs are as follows:
Dell Latitude D830 Intel core 2 duo T7250 (2.00 Ghz) 2M L2 Cache, 800Mhz dual core Windows XP Pro installed w/ SP2 4.0 GB, DDR2-667 SDRAM, 2DIMMS 160GB Hard drive, 9.5 mm, 7200 RPM (free fall sensor) I connect the digi 003 rack to a SIIG Firewire 800 Cardbus DV-Kit I uninstalled protools le, re-installed it and ran an update for 7.3.1. and i am back to the code 31 error in device manager. I can sucessfully install the drivers but now it says windows cannot load the drivers needed to run this device. |
Protools 11 Digi 003 Rack drivers | TBennett | macOS | 4 | 07-14-2013 01:55 PM |
Eleven Rack Problems with USB e Drivers | DaniTo | Eleven Rack | 1 | 06-23-2012 06:05 PM |
Digi 002 Rack Vista Drivers?? | ilovemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-20-2008 05:11 AM |
using wave drivers with digi 002 rack | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-05-2007 05:27 AM |
Problems with Quicktime playback / Digi drivers | kmoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-04-2004 10:23 AM |
