Instant Kernal Panic, Curtain of Death - Drives refused
I have a MacBook Pro 2.4GHz running 10.4.10 / PT 7.3.1 If I plug the Mbox2Mini into either USB port I get an instant curtain of death. On my Powerbook 1.25 running 10.4.10 it works fine. If I plug my Mbox2Pro in I have no problem getting PT to start but it refuses to allow any drives to be set as Record drives. The same drives work fine on the PPC Powerbook and boot as Record Drives. I have trashed prefs and Databases - to no avail Any ideas? |
Re: Instant Kernal Panic, Curtain of Death - Drives refused
Have you tried to do a clean uninstall and reinstall of Pro Tools yet?
Did you, at any point, have any other versions of Pro Tools installed on this machine? |
I too have this problem. I get a crash each and every time I plug in my brand new MBox 2. I am using a new MacBook Pro 2.4 GHz 15" machine with 2GB of RAM. I uninstalled ProTools with the exception of my plug-ins. I cleaned out all preferences and databases as well. I restarted my machine. Just to check, I then plugged the MBox 2 in without ProTools software installed - kernel panic again. I am considering returning the MBox if I don't get to the bottom of this soon. In case you want to read the log, here it is... In all of its boring-ness. Perhaps a Digi engineer can sort this out?
Thanks. DP panic(cpu 0 caller 0x001A4A55): Unresolved kernel trap (CPU 0, Type 14=page fault), registers: CR0: 0x8001003b, CR2: 0x00000000, CR3: 0x01333000, CR4: 0x000006e0 EAX: 0x00000000, EBX: 0x042ef840, ECX: 0x004bc800, EDX: 0x004b2038 CR2: 0x00000000, EBP: 0x258b3a08, ESI: 0x04a4f400, EDI: 0x258b3a7f EFL: 0x00010206, EIP: 0x3b641dbb, CS: 0x00000008, DS: 0x00000010 Backtrace, Format - Frame : Return Address (4 potential args on stack) 0x258b37f8 : 0x128d08 (0x3cc0ec 0x258b381c 0x131de5 0x0) 0x258b3838 : 0x1a4a55 (0x3d2524 0x0 0xe 0x3d1d48) 0x258b3948 : 0x19aeb4 (0x258b3960 0x258b3a7f 0x258b3998 0x127e77) 0x258b3a08 : 0x3b646487 (0x0 0x3b64fd68 0x1 0x110eb36) 0x258b3a48 : 0x3b63c3a3 (0x42ef840 0x258b3a74 0x2 0x1) 0x258b3a98 : 0x3b63c7e8 (0x4a4f400 0x4a4f5a5 0x4a4f454 0x3bd191) 0x258b3b28 : 0x9b8c59 (0x4a4f400 0x4b38400 0x258b3b58 0x381e5f) 0x258b3b58 : 0x3b639d6a (0x4a4f400 0x4b38400 0x4b39d00 0x4a4f400) 0x258b3b98 : 0x38d55e (0x4a4f400 0x4b38400 0x1 0x4343c40) 0x258b3bf8 : 0x38eddd (0x4b38400 0x4a4f400 0x43f8380 0x4b38400) 0x258b3c78 : 0x38e645 (0x4b38400 0x43326c0 0x0 0xffffffff) 0x258b3cc8 : 0x38f83b (0x4b38400 0x2 0x4b38704 0x0) 0x258b3d08 : 0x3896a8 (0x4b38400 0x2 0x4b38404 0x0) 0x258b3d48 : 0x528b64 (0x4b38400 0x2 0x4 0x0) 0x258b3db8 : 0xa3ddd2 (0x4b38600 0x4ab0b80 0x1 0x1) 0x258b3dd8 : 0xa3d886 (0x4ab0b80 0x1 0x1 0x0) Backtrace continues... Kernel loadable modules in backtrace (with dependencies): com.apple.driver.AppleUSBAudio(2.5.1b11)@0x3b62f00 0 dependency: com.apple.iokit.IOUSBFamily(2.7.7)@0x51b000 dependency: com.apple.iokit.IOAudioFamily(1.6.0b7)@0x9b1000 com.apple.iokit.IOAudioFamily(1.6.0b7)@0x9b1000 dependency: com.apple.iokit.IOUSBFamily(2.7.7)@0x51b000 dependency: com.apple.kext.OSvKernDSPLib(1.0)@0x9af000 com.apple.driver.AppleUSBComposite(2.7.7)@0xa3c000 dependency: com.apple.iokit.IOUSBFamily(2.7.7)@0x51b000 com.apple.iokit.IOUSBFamily(2.7.7)@0x51b000 Kernel version: Darwin Kernel Version 8.10.3: Wed Jun 27 23:29:36 PDT 2007; root:xnu-792.23.3~1/RELEASE_I386 Model: MacBookPro3,1, BootROM MBP31.0070.B02, 2 processors, Intel Core 2 Duo, 2.4 GHz, 2 GB Graphics: GeForce 8600M GT, GeForce 8600M GT, PCIe, 256 MB Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), 1.1.9.3 Bluetooth: Version 1.9.1f18, 2 service, 0 devices, 1 incoming serial ports Network Service: Built-in Ethernet, Ethernet, en0 Network Service: Parallels Host-Guest, Ethernet, en2 Network Service: Parallels NAT, Ethernet, en3 PCI Card: pci168c,24, sppci_othernetwork, PCI Slot 5 Serial ATA Device: FUJITSU MHW2160BHPL, 149.05 GB Parallel ATA Device: MAT****ADVD-R UJ-857E, 2.37 GB USB Device: Built-in iSight, Apple Inc., Up to 480 Mb/sec, 500 mA USB Device: iLok, iLok, Up to 1.5 Mb/sec, 500 mA USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA USB Device: IR Receiver, Apple Computer, Inc., Up to 1.5 Mb/sec, 500 mA USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA |
Corrupt sessions and the curtain of death | scottgreiner | Pro Tools TDM Systems (Mac) | 8 | 06-22-2010 12:56 AM |
OSX Kernal Panic | HiRaX | Pro Tools TDM Systems (Mac) | 7 | 02-07-2006 07:22 AM |
spinning beach ball/curtain of death! | bruce lang | Pro Tools TDM Systems (Mac) | 2 | 02-11-2005 12:42 PM |
kernal panic again | seamur | Pro Tools TDM Systems (Mac) | 13 | 11-24-2004 05:35 PM |
kernal panic | spoot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2003 05:30 PM |
