Old 10-13-2005, 12:00 PM
BookSix BookSix is offline
Default Adat or spdif
I just got my first outboard pre with digital outs (all my others are straight up analog). What do you prefer? Spdif or Adat? The pre is a two channel ART DPS II and I'm working with a 002. Thanks
Brett Michael Wiesman
www.trackstarstudios.com
Old 10-13-2005, 12:48 PM
Scotty_OiArT Scotty_OiArT is offline
Default Re: Adat or spdif
Really doesn't matter.
Unless you have other gear that needs interfacing with the hardware it should not matter.
Choose whatever makes u happy
Cheers
Old 10-13-2005, 01:03 PM
Concious Burning Concious Burning is offline
Both options are actually going to be SPDIF one is Coax the other is Optical (at least when using it in the SPDIF format). I would use the Coax connection. That leaves the optical conection open to use in the ADAT format wich will allow you to expand your 002 to 18 total inputs. You can get these extra 8 by using an 8 channel A/D/A that runs ADAT optical. i.e. Focusrite Octopre, Presonus Digimax, or Alesis AI3.
DIGI 001, PT 6.4
Dual 1.25 GHz G4, 2GB RAM, OSX 10.3.9
MBox2 Mini, PT 7.3
iBook G4 1.33GHz, 1GB RAM, OSX 10.4.8
Old 10-13-2005, 01:42 PM
Yeah, I've done the 8 adat in before at work, but we have HD there now, and I don't need extra's at home. But, I'm basically wondering if there is any signal degredation in the coax spdif as opposed to sending it optical.
Adat/spdif jeremy1230 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-05-2010 09:35 AM
ADAT or SPDIF mrblakemr Tips & Tricks 1 07-04-2006 02:34 AM
SPDIF and ADAT sikblades 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-15-2005 09:03 AM
ADAT or SPDIF godscent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-07-2004 10:29 AM
SPDIF to ADAT Percustard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-09-2004 07:42 PM
