Old 10-14-2004, 06:18 AM
haldude haldude is offline
Default Sending sessions to other ProTools user
Can I use "Compacting an Audio File" to reduce a session size so that a CD copy can be made for my brother to use on his ProTools system?
I don't need earlier "takes" or audio.
Thanks, Hal
Old 10-14-2004, 11:50 AM
mindnoise mindnoise is offline
Default Re: Sending sessions to other ProTools user
HI,
rather select "select unused regions" from teh audio files list window, then "remove unused regions"
this will remove any regions that are not in the EDIT window.
Then select " Save Copy of Session as..." from teh files menu.
this will get you a most lean copy of your session.
regs
last: PT11.3.1
Problems Sending Pro Tools Sessions Streetcurbs Pro Tools M-Powered (Mac) 4 03-15-2010 10:58 AM
Collaboration: Sending PT Sessions and OMF files Sonny in London 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-29-2006 07:25 PM
Sending sessions over the net? Vinnyvenditto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-24-2005 04:59 AM
Sending Sessions Via Email? 100grit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-12-2005 10:00 PM
Sending Sessions Via kaaza? da BaSsTaRd! 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-11-2003 12:58 AM
