Old 11-12-2021, 11:28 AM
IrelandM IrelandM is offline
Default No sound from ProTools
To ProTools Users,
I lately made some adjustments to my studio setup audio cables etc to clear around my floor space. Also did a new update to ProTools Ultimate 2021.10.0 and updated the macOS to Mojave 10.14.6
I run a MTRX Studio with DADMan and Thunderbolt HD Native but currently cannot get any sound out of ProTools Ultimate even after defaulting to stereo in the I/O settings. I updated the HD Driver to 2021.10 could this be the area of my problem.
I hear audio from the DADMan software but I have no PT Thunderbolt option available within the Mac's system settings as one of my output devices.
Any help would be gratefully appreciated.
Regards
Old 11-12-2021, 11:41 AM
Default Re: No sound from ProTools
"I have no PT Thunderbolt option available within the Mac's system settings as one of my output devices."
So what is the playback engine actually set to?
Did you do a full clean macOS install or an in situ upgrade?
You may not have granted security permission to install the driver/kext. Did you do that? You have to carefully follow the instructions/screen prompts. Lots of discussion on DUC on this. ... but AFAIK the permissions might be grandfathered in if you did an in situ upgrade, but which I would not recommend for so many other reasons.
And finally, it won't cause this problem but don't forget to enable Security & Privacy>Privacy>Microphone permissions for Pro Tools.
Old 11-12-2021, 12:35 PM
To Darryl,
I set the Playback engine to ProTools Aggregate I/O.
But have options for Dolby Audio Bridge also Audio Cast and Internal Speakers.
In Situ upgrade from macOS Mojave 10.14.5
I may not have fully granted security permission to install the driver/kext.
But granted permission within the Security & Privacy settings as the ProTools.app is showing ticked for access.
Should the microphone icon also be showing in the Privacy area or just the Pro Tools app.
The HD Thunderbolt is not showing at all in the Macs sound preferences.
Old 11-12-2021, 01:00 PM
Rerun the driver installer and make sure you follow the exact instruction for approving the driver install.
...likely because there is no driver installed.
Trying to use aggregate IO is not going to help you.
You have a driver problem. Fix that.
Lots of past discussions about approving driver installs on DUC that may help you. I'm not going to repeat all that here.
Old 11-12-2021, 02:15 PM
creativecontrol's Avatar
Here's the Kbase for reference that summarizes all of these HD Driver installation processes:
https://avid.secure.force.com/pkb/ar...ation-on-macOS
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-15-2021, 05:41 AM
Having tried to update the Avid HD Driver from 2021.6 I cannot uninstall it as I cannot even see the DigiDal.kext, to verify the version that I have installed:
I only see an extension named AvidDX version 5.9.2 and nothing called DigiDal.kext
I tried to do a clean reinstall of the 2021.6 HD Driver but so far nothing is working and the HD Thunderbolt output is still not available within the Mac's settings.
A further note regarding the HD Thunderbolt it showed briefly inside the sound preferences but then it disappears from the menu.?
Regards
Old 11-15-2021, 05:44 AM
I believe the best course of action at this time would be to log a support case and they can certainly help you sort this issue ->
https://avid.secure.force.com/pkb/ar...-Case-Creation
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-17-2021, 02:04 PM
To ProTools Users,
Update on this thread, it's still not resolved but working with Avid Customer care.
Old 12-16-2021, 11:45 AM
To ProTools Users,
Having contacted Avid support I still have problems getting any audio output even from ProTools Ultimate 2021.12.0 after updating the HD driver and installing the newer software from the previous version.
I tried a DigiTest and include some screenshots below would anyone know how to fix this No sound issue.
Regards
Old 12-16-2021, 11:54 AM
Greetings,
Was support able to help you get the HD Drivers loaded correctly?
What is your case#?
Does HDNTB show up under AudioMIDISetup > Audio ?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
NO Sound from Protools 8.0.5 Hansemann64 Windows 6 11-06-2016 09:15 AM
no sound from protools first sesmalife Getting Started 1 04-02-2016 02:51 AM
No Sound in ProTools Alien Frequency Eleven Rack 2 04-08-2015 03:29 PM
No Sound in ProTools Sage Maduin Windows 0 12-11-2012 07:03 PM
Does Protools 6 have a sound? Matt_G Pro Tools TDM Systems (Mac) 5 03-26-2004 10:11 AM
