Old 11-02-2021, 02:07 AM
ejsongs ejsongs is offline
Default Re: HDX Driver No Longer Shows after 2021.10 Install
how can you tell which driver you are currently using?
ej
Old 11-02-2021, 08:01 AM
Dizzi45Z Dizzi45Z is offline
Originally Posted by Eric Lambert View Post
I had the same issue. In my case, I installed PT with the 2021.7 installer, then used the separate Driver Installer file. I went back to 2021.7 (along with its driver) and got the interface to show up again. So I tried one more time but this time I used the Driver Installer file that came within the PT installer. Whether or not that difference was elemental, it worked the second time around and has been fine since.
I wonder if there is something wrong with the separate Driver installer. That is also the one I used first and has caused all the problems of not showing up. I think I’m going to try your direction of reinstalling the old driver and then upgrade from there again using the driver that is included with the Pro Tools 2021.10 installer and see if that also solves my issue.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 11-02-2021, 03:10 PM
Eric Lambert's Avatar
There does seem to be evidence that the separate driver installer is problematic, at least for some.
Old 11-02-2021, 04:14 PM
arche3's Avatar
arche3 arche3 is offline
I had the same issue. Luckily I kept doing different things amd it finally stuck.
Sent from my SM-G986U using Tapatalk
Old 11-02-2021, 11:40 PM
TrentWilliams TrentWilliams is offline
Default BUG UPDATE: HDX driver not loading on boot
UPDATE *This has been recorded as a bug with the 2021.10.0 HD Driver.
Current workarounds are to disable SIP.
Hey all,
The HDX driver in my machine doesn’t seem to be loading on launch, I have to launch it manually after boot.
I’ve followed the instructions found here:
https://avid.secure.force.com/pkb/ar...rue&popup=true
But this doesn’t fix the issue,
Any help or advice is appreciated.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #16
Old 11-03-2021, 04:53 AM
arche3's Avatar
Default Re: HDX driver not loading on boot
ok...don't laugh. (uninstall HD driver. restart.) And this is the don't judge me part...
what i did was open security. open the lock. leave it open and system preferences running. install HD driver. It didn't ask for the OK prompt.
Restart Mac. then it worked on reboot since then.
  #17
Old 11-03-2021, 12:59 PM
Thanks for the advice, I tried your suggestion however it still isn't working correctly.
  #18
Old 11-03-2021, 04:31 PM
Arichlsss Arichlsss is offline
Mine setup worked fine for a few days but today I went to lunch for several hrs and the computer went to sleep today. I came back to a broken system… no HDX driver in audio midi showing up …
  #19
Old 11-04-2021, 03:52 AM
richardbutler richardbutler is offline
Same issue, has completely messed up our Dubbing Theatre, right before a teaching session. Trying my best to get it working with minimal time and students waiting, most embarrassing.
Very disappointing Avid
  #20
Old 11-04-2021, 05:50 AM
I decided to roll the dice and install the hd driver that is included within the actual pro tools installer. I did not uninstall the previous driver first though.
So far no issues for me.
2010 Mac Pro
3.46 ghz 12 core
Mojave 10.14.6
64gb ram
Hdx1
ipad no longer shows in Surfaces SoundPark489 Avid S1, S3, Dock and Control App 4 07-24-2019 12:50 AM
Downloaded Soundflower Apollo no longer shows up! wedgewedge Pro Tools 10 0 04-10-2014 06:48 PM
Mbox 3 pro Just popped LOUDLY no longer shows firmware. Intuition FireWire & USB Audio Interfaces (Mac) 5 10-14-2013 11:28 AM
Plugin no longer on drive, but still shows up in menu in LE mathiasriffman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-11-2008 11:15 AM
CD on desktop no longer shows a volumn in OS 9.2 fifty8th1 Pro Tools TDM Systems (Mac) 0 08-24-2003 10:53 AM
