Can you record the audio/tones of plugins so you can reduce the amount you are using?
I keep having a cpu error and I want to print/record all of the tones generated by Xpand2, and some of the other plugins so I won't be running so many at once.
Excuse me if I'm not using the right terms. Im a fossil from the analog era. |
Re: Can you record the audio/tones of plugins so you can reduce the amount you are us
Welcome to the DUC That's a typical great idea to record the tones of plugins and VIs to audio tracks...either you're happy with them and don't need to make any tone edits, so go ahead and print the instrument, or just print them now for the sake of saving CPU to get you by for tracking other 'real instruments' and voices, and knowing that you can go back to the midi/instrument tracks right before mixdown to make any adjustments, but at a higher CPU sample buffer setting.
Buss the output of your midi/instrument track to the same buss input of a new (stereo) audio track...arm and hit record for the new track. Make sure all your plugins are the most current for your version of PTs.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
solo it and bounce it to disk and re-import it, check it sounds the way you want, then ditch the cpu hungry virtual instrument.
Or bus it to a new audio track and record it.
It's a good idea of course. I often to that (bounce to disk) since I don't have a mega computer from another galaxy. It's a great and clever way to work and get rid of all the cpu eaters, as long as you are sure about the audio you are about to record and you are sure it's finnal and you like it that way. Keep a few backup sessions with still the virtual instrument and all its effects in it, I always save the patch/preset before deleting the whole thing, might sounds stupid but trust me s--t happens! ;-)
MacBook Pro - OS X 10.6 - Pro Tools LE 8 - Mbox 2 Drone / Ambient / Experimental |
You don't have to create back up sessions! You can just set the "mother" track to Inactive...even Hide.At least you're still able to reprint it later if it doesn't fit the mixdown in the same session.
Just my two cents.
Green Room Studios, France Mac Book Pro i7 15"4 Mac OSX 10.6.6 PT 9.0.2 DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate. PTLE 8.0.4 002R Unit and MBox Mini SSL XLogic Alpha Channel. SPL Goldmike valve Preamp. DBX Analog Compressors, Gate and Eq. Monster Cables Home made & Neutrik Patchbay. Brauner, Shure, Seinnheiser and T.Bone mikes. Tannoy 8D Active monitors. |
That's a pretty sweet tip, never really thought about doing that hmmm... But I wonder, is making a track inactive the same as deleting it, cpu power speaking? Making it inactive makes it totally cpu power free?
Yes, that's exactly what it does. Besides saving cpu power, it also frees up a voice to use for another track.
iMac 21.5" (2017) Intel Core i7 3.6GHz, 1TB SSD, 32GB RAM PreSonus Quantum 2 interface Mac OSX 10.15.6 Catalina 1 G-Drive Pro 4 TB 2 G-Drive 6 TB ProTools 2021.3.1 Melodyne 5 Soundtoys Bundle 5.3.2 Omnisphere 2.6.2 Massey L2007 Superior Drummer 2.3.2 Komplete 13 Ultimate |
there you go, never knew that, I was backing up the session file before deleting. As you say, set it to inactive, who says we don't have a freeze function!!!
me.
it's not the same.
Lenovo T61 T9300 Core 2 Duo 2.5ghz 4GB DDR2 2 1TB FreeAgent Xtreme External Drives SIIG FireWire Express Card Windows 7 Ultimate X64 Pro Tools 8.0.4 LE Digi003 Rack || PreSonus D8 || ART MPA Gold || ART PRO VLA II || Ensoniq DP/2 M-Audio Axiom 49 || Behringer BCF2000 Yamaha HS50Ms Bands: Captain Starr || stereoINs Drums: 1 || 2 || 3 Guitars: 1 || 2 || 3 |
Reduce latency when monitoring audio inputs | digi003 | Pro Tools 10 | 3 | 02-15-2012 05:19 AM |
I like the tones that are on my synth, but how do I record them? | tdubthatsme | MIDI | 2 | 02-24-2011 11:33 AM |
Plugins Reduce Gain? | tntmail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-24-2002 06:39 AM |
Q: plugins/settings to reduce hiss/static | Esteban | Tips & Tricks | 3 | 09-18-2002 03:26 AM |
Do new/extra plug-ins reduce amount of free DAE memory? | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-24-2002 05:18 PM |
